Leica R 100/4 macro: what do i need to know?
rbelyell
5:43 PM
i want to buy this R mount slr lens for normal use with a 4/3 mount camera i just bought (not m4/3). there seem to be many iterations (2 cam, 3 cam, 4 cam, ROM etc), some say they need bellows or some other attachment, others dont, some are expensive, some a few hundred dollars. ive been around cameras for many years, but i find this particular situation extremely confusing. can anyone help me sort it all out?
thanks,
tony
I am no expert but there are three versions:
11230 which was for use with bellows on SL and SL2 'Macro Elmar'
11270 which was for use with bellows an R cameras 'Macro Elmar'
11232 which was for use either by itself or with it's extension ring. 'Macro Elmar-R'
The cams do not matter if you are using it on a digital camera and you don't need the rom.
The point being that as I understand it 11230 and 11270 need bellows to work. They have no focussing mount.
11232 goes from infinity to 1:3 when attached directly to the camera and right up to 1:1.6 with its extension ring 14262. If you want a general purpose lens capable of close focus this is the one you want.
I use the 60mm f2.8 Macro Elmarit-R which is excellent
thank you michael, thats really helpful. i assume the 60mm doesnt have these other weird variations and issues? its more of a 'straight up' normal everyday lens?
I wouldn't describe them as weird variations or issues. 11230 and 11270 are truly excellent lenses designed for a specific use with a specific mount and 11232 was designed as an all purpose lens with a good close up ability.
The various versions of the 60mm 2.8 all have focussing mounts and therefore can be described as all purpose. 11205/11212 for L'flex, SL/SL2 and R. 11253 R only. 11347 ROM.
Search the net and you'll find descriptions of Leicaflex and R mount development but for your 4/3 camera it is, I think, irrelevant if you get the right adapter. 11205 ought to be the cheapest and often comes with the extension tube/ring. I think they are optically very similar.
May I ask the obvious question?
That is; why not an Olympus Macro lens? They make/made some excellent ones in the "FourThirds" mount. I've the 50mm f/2 version and rate it as excellent...
Regards, David
sure david, its not that i want a macro lens in particular, though thats a nice bonus. its that i want a 100mm (200mm equiv) lens to complement the 14-50/2.8 (28-100mm equiv) leica kit lens. there arent any such 4/3 primes, and that mount doesnt accept many third party mounts. it does accept leica R mount, and it just happens ive for some reason been interested in this lens for a while. i think itd be a great telephoto and outdoor portrait lens.
Keep it in mind, that this is not the sharpest Leica lens, particularly at infinity. For that you would be better off with one of the M or R mount 90mm Elmarits, or even the cheap C Elmar 90/4 M, which will cost you less than the 100/4, will be much smaller, lighter and sharper at infinity.
thats great information, thanks. i have the elmar c and think it is incredibly underrated. but m mount lenses cannot be mounted on 4/3 cameras, which are essentially slr's with some kind of altered mirror. i will look into the R 90s as you suggest, because i may well want to use the lens at infinity. are there different models of this lens also?
There are 2 versions of Elmarit r 90 - both made by Mandler. I have the v1 and I like it. Those who compared extensively versions 1 and 2 of Mandler's R lenses claim, that versions 2 were typically sharper, but with worse bokeh. Given that you will use this lens on a cropped camera there won't be much difference between the two versions, so look for better condition and price.
