Leica R repair?
chaospress
2:49 PM
Just wondering if Leica or anyone else still services the Leica R cameras, particularly the R5.
Sorry, if there's an R forum here feel free to re-direct me. I don't see one.
Thanks...
Don't know how one could call the SL a rangefinder, but to each their own.
Leica USA in Allendale, NJ will work on R lenses, but I don't believe they'll do the cameras. Lack of parts is the usual excuse. But you could ask.
Leica Camera USA Inc.
1 Pearl Court, Unit A
Allendale, NJ .7401-1610
PH: 201-995-0051
However, I would not recommend them. They do good work, but it takes them forever, and they'll give you the run around as to when you can get your gear back.
I'll be looking for R system repairers myself, but didn't have much luck the first time around. That's how I wound up sending a lens to NJ.
PF
DAG replied that he works on the R lenses, but that was in response to me asking about the R cameras, so I emailed him back. Maybe he just doesn't work on the cameras. Sherry doesn't list R cameras on her website, though she does the SL.
There seem to be more R6's (mechanical) out there than R5's (electronic). The R6 is going for a bit more for some reason.
I had an R5 in 2011 and should have kept it.
Just moved this thread- I mistook the 'Leica SL' forum for a forum on the Leicaflex SL, thinking it was the closest thing I could find to a forum for the SLR film R cameras…
Neither Leica R or Leicaflex cameras get a lot of attention these days I suppose.
Call Dave Easterwood of Dave’s Camera Repair. He’s a master repairman with over 40 years of experience and two storage units full of parts for old cameras. Search for his name on this site for more detailed posts I have written about him. I bet he can fix your R.
dave@davescamera.net
*(734) 433-2640‬
Steve Rosenblum
Sherry Krauter fixed my R6 about five years ago. When I first inquired about it, she recommended I consider simply buying a new body rather than have the repair work done. One issue for the R cameras is that parts (if and when available) have gone up in price along with all things from Leica.
Ultimately I decided to go the repair route. It was a personal rather than practical decision, but I was glad to have the insight before pulling the trigger. She did great work and the camera functions as new to this day.
Thanks all… Yes, I'm getting the idea parts may be scarce, possibly. If a camera sale has a return option and the camera is good initially it's likely it will last awhile. R5's aren't extremely expensive.
I'm in California btw..
I've had Sherry work on R lenses and various Leicaflex models over the years. I've read that there are some R model cameras which Sherry will not work on but none of that is first hand information.
Another alternative might be to convert an R lens to Nikon mount. I've got an F2 that will no doubt outlast me. Trying a 40mm f/2 Voigtlander out on it now.
That's an okay solution to using R lenses, but says nothing about repairing an R camera body. The best solution to continuing use of the great R lenses is to buy a modern Leica SL digital body. Leica R lenses work beautifully on the Leica SL, much better than on any Nikon SLR. But of course, the Leica SL is a digital camera ... which might not be your desire. :angel:
Some time ago (a couple of years at least), I asked Don Goldberg whether he could do a CLA on my Leicaflex SL. He said yes, but also warned me that if he found some kinds of problems then parts might pose a problem. My Leicaflex SL has continued to work without any problems, but I should likely call him again and ask if he can still do a CLA.
Leica will still do some service work on the R8 and R9, but since the very last of them was produced almost a decade ago, parts for them are getting scarce too. They did tell me (again a couple of years ago) that they could do the 1-cam to 3-cam update on my 1964 Summicron-R 50mm lens, which would include a full lens CLA, calibration, etc as well ... It's just that that service would cost more than a newer, near-mint replacement lens so it's hardly worth doing. DAG will do the cam update as well, for less money.
There is a mailing list specific to Leica reflex camera users/enthusiasts. That would likely be the best source of information on where to find service and repair facilities: http://lrflex.furnfeather.ca
G
Two years on, they are probably even more difficult to have repaired, although there seems to be something of a film resurgence (hah! - at least in my household).
R bodies are now so cheap and readily available that professional repair has to be uneconomic. However, in my experience the R series cameras from the later R4 model onwards are pretty reliable, despite their age. All I have seen with mine is failed viewfinder metering mode indication LEDs (no great problem, as the body in question continues to function normally) and isolated incidents of the shutter speed indication and frame counter going awry.
If you are determined and have a steady hand, either of the latter problems are easily fixed by taking off the top plate and relocating the comedy fishing line that pulls out the tape on which the speeds are printed (I am not joking!) or retensioning the rather weak return spring of the frame counter.
Otherwise, of course, you can bin the thing and replace it for £100/$100 or less (I've seen a really nice, rare-ish R4S Mod P on sale for just £89 in recent weeks).
My tips to preserve these fine cameras in working order are: replace the film window and opening-back light seals with any one of the cheapo eBay kits (a really easy DIY job) and always leave the camera with the shutter wound right down to the orange, mechanical default 1/100th setting (which takes all the tension off the speed readout tape) and the frame counter set to 'S'/zero (ditto for the weak return spring).
Oh, and when it comes to which one to buy as a replacement, as the books don't say, the late-model (post '85 is my estimate) R4 has both the much brighter screen fitted to the R4S Mod 2/Mod P and - for all us obsessive Leica nuts - the dinky cast red-dot badge fitted to the R5 and later, improved R models.
So; enjoy!
