Calzone
Gear Whore #1
I don't think anyone here at RFF is dishonest or biased. The other side....
Correct me if I'm wrong, wasn't Leica tossing in defective sensors under this "Goodwill" before September 2015 and Monochrome not defective sensor was not even ready by this time?
https://www.l-camera-forum.com/topic/249569-leica-m9-corrosion-sensor-replacement-starts-now/
Don't you think it is common sense to wait and see if second round is actually working one, after first round with defective sensors failure? And do you think it was honest to cut under short notice by August 2017 started in September 2015 program?
Are you blaming users for the rush to send cameras after all of this mess which lasted for years, but was cut short once they find the solution?
KoFe,
I'm glad that you brought up this fact and added some clarity through the link and brought up a timeline of when the opportunity to get a sensor replacement that corrected the corrosion problem was beginning to be offered. I think the initial announcement might of been in August of 2015, and it makes sense that Leica's time frame of the cut-off deadline likely was two years from that anniversary.
It is true that Leica did replace sensors with a replacement sensor that could be spun as a "Time Bomb" earlier/previously. This definitely muddled things up a created problems and conflicts for many. In many ways this exacerbated the situation.
I am saying why did not many act after September 2015 like I did (December 2015 in my case) and send in their cameras at that time? I am also saying that perhaps in August 2015 maybe Leica began offering replacement sensors that were upgraded to correct the corrosion problem. And now that a timeline is somewhat established people really had two full years to send in their cameras.
I'm also suggesting that even if Leica gave a year's notice before the deadline that this unavoidable logjam and delays likely still would have happened because of human nature.
I will even say that I waited, procrastinated, and gambled.
Cal
