Leicameter MR problem
Andrew3511
11:55 PM
Surrey, UK
I've bought a Leicameter MR recently for my M2. Worked fine to start with but after a couple of days use it went dead, so I replaced the battery. I used the alkaline PX625A and it worked for a short while then stopped working again. As I'd had the battery in the cupboard for quite a while as the spare for the OM1 I got a fresh one but same thing happened, it worked for a few minutes then stopped again.
Is it the voltage? Should I look for a different sort of battery, if so what and where, or is it likely to be the meter needing servicing?
Any help gratefully received
Andrew
Are the formerly good batteries dead when the meter quits after a few minutes?
If so, sounds like a short.
