Edubarca
Thank you very much for your help. I'll wait until my lens arrives (I am in Colombia) and as soon as I install it, I will let you know if I run into any trouble. It seems it is very easy so I imagine i will have little or no problems.
Thanks again!!
EDUARDO
Thanks again!!
EDUARDO
Edubarca
My dear friends, unfortunately, the order for the extension was not successful. I am respectfully asking you my friends to help me, please, find another extension for my Focomat 1c and my Nikkor 50 mm f/4 lens that does cost a fortune. Being out of the US, it is not easy so any help is deeply appreciated. Thanks very much and best wishes
EDUARDO Here's my email if convenient. edubarca1946@gmail.com
Graybeard
Longtime IIIf User
Look on eBay for extension tube sets made for Barnack Leicas.
These are frequently offered by FSU sellers. There is usually the correct length extension tube in these sets. The el Nikkor 50mm on my Focomat uses a tube obtained in this way.
Edubarca
Thanks, please, what is FSU? How do I exactly write on Ebay search for the extension?
Graybeard
Longtime IIIf User
FSU is an abbreviation for "Former Soviet Union". Most often it will be Ukrainian or Russian vendors offring the tubes.
Search eBay for "Leica Extension Tubes" and be sure to buy ones with the Barnack (sometimes called LTM) screw mount, not extension tubes for the Leica Visoflex or Leica reflex.
Emile de Leon
You can also stack together..a bunch of old/used 39mm filters to replicate the DOORX..just remove the glass..
Edubarca
Hello my friends, I finally got my extension. It fitted perfectly. A couple of questions: If the lens screws perfectly to the enlarger, what's the extension for? And, please check the picture: The Nikkor lens came with this ring. What is its purpose? I didn't need any extension on my old Fujimoto enlarger. Thanks for your invaluable help.
EDUARDO
EDUARDO
Emile de Leon
1C wont focus without the extension ring..If the lens screws perfectly to the enlarger, what's the extension for?
Retaining ring for boards w/o threads..notches are for tightening..The Nikkor lens came with this ring. What is its purpose?
Edubarca
Sorry but didn't catch this one, What "boards" are you referring to?
Thanks!
Lens boards without lens threads... A couple of my Beseler enlarger lens boards were like this.
Edubarca
Thanks!!!!
Edubarca
Sorry to continue bothering you but I still find several issues that I don't understand. My old Fujimoto, as stated before, did not have so many little issues.
I have seen something about "Newton rings" and a lens or something that prevents this. Can you please explain me a little more about this? I am forever grateful.
Emile de Leon
The 1C is an autofocus enlarger..so it has more things to consider in using it..Sorry to continue bothering you but I still find several issues that I don't understand. My old Fujimoto, as stated before, did not have so many little issues.
I stopped using the condenser against the neg for dust and Newtons ring issues...and manual focus it instead..but if you want corner to corner sharpness..and a flat neg..the condenser is the way to go..
But you can get a spacer made for the enlarger but it is expensive and hard to find..it attaches to the condenser..or you make one yourself..
https://en.wikipedia.org/wiki/Newton's_rings...I have seen something about "Newton rings" and a lens or something that prevents this. Can you please explain me a little more about this? I am forever grateful.
Edubarca
Thanks Emile and friends. Sorry for late reply, I have been a little busy these days. But now I return to my almost complete darkroom including my Focomat.
I don't want to appear dumb, but since my old Fujimoto and Minox enlargers, are simpler, I find myself with issues that I have never dealt with before using enlargers. Case in point "autofocus" I know what autofocus is in my Nikon digital camera, but what is it in my enlarger? If you can give me a little more explanation, I would appreciate it very much. You say, Emile, that you don't use this "autofocus" feature. This means I can focus just as I used to do it with the Fujimoto and Minox? And if I don't use it, it means no Newton rings?
Edubarca
And concerning the light bulb, since nowadays, common, traditional tungsten light bulbs are almost unavailable, what size in watts you recommend me when using modern LED bulbs?
Thanks my friends!!!
EDUARDO
EDUARDO
Erik van Straten
This.
HEILAND ELECTRONIC LED Kaltlichtquelle für Leitz Ic
Erik.
Emile de Leon
Whoa Erik..that is one pricy lightbulb...lol...
But if you want to manual focus it..you will have to pull the lil metal thingy off that guides it..
Unfortunately..I lost mine after I took it off...and have to locate a new one..
If anyone has one to spare..let me know..
Yup..my old Fujimoto and Minox enlargers, are simpler,
You never have to focus it..if I have time the next few days..I will post pics of what this is about..autofocus..but what is it in my enlarger
Edubarca
Hi Erik, Perhaps I wasn't clear enough. I am referring to the light buld that goes inside the enlarger. I don't know if the box light you recommend me is appropriate for this purpose. Apart from that, it is extremely expensive for us Colombians with a weak currency. Thanks!! Best wishes.
Erik van Straten
This device - a cold light source - takes in your enlarger the place of the old fashioned light bulb. It can be used for split-grade enlarging and many other enlarging techniques.
Yes, it is expensive. Unfortunately.
Erik.
Erik.
