Leitz Valoy II
Accessory List form Valoy II Brochure
I have three of these now, plus a Focomat 1c.
Here are the bit's and pieces you need to extend the Valoy II's function.
Accessory/ Telex Code:
Click-stop aperture ring
for 5cm ELMAR lens of LEICA VALOO
Alternative lens for use in place of Leica lens:
5cm FOCOTAR enlarging lens DOOHF
with click-stop aperture setting
Swing-out orange filter, FTOOS
adjustable in height
Film pressure frame for fitting NEWOO
over condenser lens to prevent
Newton's rings
18 x 24 cm printing board with adjustable FPYOO
masking strips and paper stops
80cm column VOOQF
Interchangeable Film Masks:
18 x 24 mm VNAOO
24 x 24 mm VNIOO
24 x 36 mm (spare) VNEOO
3 x 4 cm VNOOU
4 x 4 cm VNUOO
Single Negative Mask 24 x 36 mm VBOOP
Hinged glass plates, 3.5 x 12 cm VOOMD
for use with VBOOP mask
Mask for single negatives 3 x 4 cm VAZUP
Mask for single negatives 4 x 4 cm VAZIS
Hinged glass plates, 5 x 16 cm VOONR
for use with VAZUP and VAZIS
Spare opal lamps: 75 watts FLABU
150 watts FVLOO
Copying Accessories:
Adaptor for mounting UWOOS
the LEICA focusing stage
(For focusing stage see List Photo No. 8206a)
Further part required UWYOO
(in addition to UWOOS)
with universal focusing bellows
I also have scans of this brochure which pretty much tells you everything you need to know to operate a Valoy II. I could email them to you if needed...
I now want to rewire my valoy II but I can't yet see how to disconnect the bulb assembly from the head. Is there a particular way to do this?
Just checked how to take the wiring from the lamphead of the Valoy II.
- on the outside of the enlarger head loosen the turning part closest to the head. I think you need to hold the socket to do so. Just turn it anti-clockwise as far as it goes
- then on the inside of the enlarger head loosen the lowest part of the socket by turning it anti-clockwise (see photo) - you hold the parts on the outside while doing this
- From here on I did not go further, but you will need a small screwdriver to loosen the two wires. After that you can pull the whole thing out, or maybe you will need to loosen the other part on the outside to be able to pull everything out . . .
Good luck
Just in case you still need to change the wiring of your Valoy II:
The actions in my earlier post still apply . ..
I just had to do this myself and ran into the final action you must do. On the outside the round part that sits furthest from the lamphouse, it also turns lose. BUT you need a tiny screwdriver to unscrew this tiny screw on the side !!
Attached an image after the whole thing, just to show where to find the small screw . . .
