Leningrad advice?
Mikael.N
12:17 PM
Sweden Lulea
I have been thinking of buying a leningrad camera is there some one here that have used one.How are they tho handle?reason for buying vf for different lenses.i really want a portrait lens( j9)
Advantages: Great finder with etched framelines. Motor drive can come in handy. Hefty and solid feel.
Disadvantages: Motor drive is prone to breakage. Slow rewind. Lenses with a big throat probably don't fit, as there camera has a ledge outside; I haven't tried that. Rangefinder patch doesn't show overlapping images, but you just align things at the top and bottom edge, which requires vertical structures to be present. Expensive.
Disclaimer: I've had one for about a week before I gave it back to its rightful owner, I guess a regular Leningrad user could say more.
I agree with Philipp. VF excellent, the r/f patch does take some getting used to, faces may prove tricky until you develop a way to work with it. Motor drive is a repeater mechanism rather than continuous, you need a fast finger to get 3fps.
If you obey the rules with this one there are no problems. Do not overwind the spring and do not try to set/use the self-timer if the motor spring is not chanrged. you WILL break it. One reason why Soviet Camera Store offers no warranty.
As for lenses J-8, J-11, J-12 and Orion 15 fit fine. I can see the J-9 being a potential problem.
Film loading would be easier if you had an extra hand and rewinding is painfully slow, especially considering how fast you use film.
It is a heavy but well made camera which is excellent in the hand and I'm only sorry I don't take mine out more, but it does tend to scare the natives, goes off like a gunshot.
If you do decide to go for one get the r/f checked. the internal frame can be very badly cast and they warp with time, thowing the vertical off - according to Oleg unrepairable unless you find a donor.
Should you buy one I'm sure you will enjoy it, even if it doesn't become your regular shooter.
JonP
Interesting camera but, as pointed out above, there are a LOT of lenses that don't fit because of that curved ledge above the lens mount. Basically, any lens with a base diameter larger than 1-15/16 inches will not fit. During the time I owned a Leningrad, I was disappointed to discover that NONE of my Voigtlander or Canon LTM lenses (except the skinny Canon 50/1.8) would fit.
Another peculiarity that can cause problems is that the sprocketless film advance design causes the spacing between frames to increase gradually as you move through a roll. At the beginning the frames almost touch each other; by the end of a 36-exposure roll they're much farther apart than standard. This was a compromises that the designers accepted in order to eliminate the need for a sprocket shaft system. It's not an issue if you develop and print your own film, but if you want to use lab processing it will cause havoc with automatic film-cutting and slide-mounting equipment.
Also, changing film is very slow because the rewind knob works slowly and the back-locking mechanism is difficult to unlock.
My Leningrad photo page is still up; here's a link.
If you want a former-Soviet LTM camera that has finder frames and is suitable for rapid action, you might want to consider the Droug as an alternative. Its finder shows frames only for 50mm and 85mm lenses, but you did mention that you're looking for a portrait lens, and 85mm works well for that. I've got a page on the Droug, too -- here's a link.
I'm not dissing the Leningrad as a collectible or a "fun" camera -- it's a fascinating and clever design. But if you want to do RF portraiture with minimal headaches, I have to say it wouldn't be my first choice.
I have to agree with jlw here. The Drug would probably be more appropriate, but a problem with both is if their unusual wind mechanisms fail, and they do, you're stuck with a paper-weight, albeit an unusual one.
The shutter itself is quiet, its just when you release the shutter release and the autowind kicks in that you get the noise, and it is rather like a loud mirror slap.
You could always take you photo then slink away before releasing the release!
