Leningrad
Screwy
All the gear no idea
3:34 PM
Bradford,West Yorks
I have two of these (One a parts/repair ) on the way , I'm sure someone,s posted that they have one . Anything I should watch out for in particular using one of these for the first time ?
Thanks in advance
Paul
(edited title)
meter or camera??
if meter - Test it against another 'working' meter. Otherwise, they're dead simple. I love my leningrad 8.
if camera - lucky *******!
oops 😱 Yes the Camera 😀 I keep looking at Russian meters but I have various Westons and a few Norwoods , I'm not sure the wife would let me get away with adding Russian light meters to the ever expanding selection of Russian cameras in various states of disrepair I keep acquiring 😀
Paul
Paul
Never set the self-timer without the shutter spring being charged - when you wind and release the shutter the timer will self-destruct, big-time.
You may find the cameras eyebrow prevents your J-9 mounting.
Oh, and there will be no secretive shooting - it's loud.
But I love mine.
-- Frame spacing will be uneven because of the sprocketless film advance, so I suggest you avoid shooting slide film unless you're willing to cut and mount it yourself. In fact, if you shoot neg films and have a lab develop them, you'll also probably need to request the film back uncut so you can cut it up with scissors.
-- Don't wind the spring too tight or it won't advance (especially a problem on earlier production models.) The mechanism is controlled by tension, so too much tension (from either the winding spring or the film) will lock it up. If this happens, one way to free it is to turn the shutter speed dial slightly against spring tension and then let it spring back; often this will let the camera advance. This is just an emergency measure, though -- don't know how bad it might be for the long-term health of the camera.
-- DO NOT mount any lenses with 'tab-type' rangefinder couplers (tab type has just a tab or projection that presses against the camera body coupling lever, rather than a cam that completely encircles the back of the lens.) The Leningrad's coupling lever doesn't have a roller on the end, so if you mount a tab-type lens, the lever can act as a ratchet and keep you from removing it again! If that happens, the only cure is to remove film, open the shutter on B, and reach in through the back to restrain the lever as you unscrew the lens.
Tab-type couplers are most commonly seen on non-FSU tele lenses. To be fair, this isn't exclusively a Leningrad issue -- most FSU cameras have non-roller coupling arms and can get into the same problem. The only exception I know of that DOES have a roller coupling arm is the Droug.
Thanks for the reply,s everyone and also thanks for your patience 😎 as after doing a search of the forum (which I should have done before starting this thread 😱 ) I see that you have posted most of the above previously.
Oh and jlw nice pictures of the black Leningrad , I will have to see what sort of condition the parts/repairable is in 😉
Paul
