GMOG
Thanks for the advice on the Incabloc springs, it helped a lot! I successfully opened them and removed the jewel holders from the balance cock and the mainplate last night. I ended up having to remove the balance from the movement anyway, in order to get to the pallet fork and pallet bridge.
You bet! Glad it helped.
Yes, you have to remove the balance wheel from the movement to get to the pallets and bridge. When removing the balance don't detach the hairspring stud from the balance cock. Use the cock to lift the balance out of the way and also when returning it to position. The hairspring will stretch out and leave the wheel hanging down some but it won't do any harm so long as you don't force it enough to actually bend it.
Maybe you already understood, so apologies if I am repeating something you already know. The idea is to touch those delicate parts as little as possible. Separating the hairspring from the cock is one of the more risky things we do, so if we don't have to do it we don't.
