raid
Dad Photographer
I have no hood right now. There is no old hood here.
Would any of the two hoods for which I posted the links work?
JMQ
Any hood for 50mm lens that is 43mm and 0.75 pitch.
raid
Dad Photographer
Will the sellers state the pitch number?
Clint Troy
Ask the seller. Geez.
JMQ
Most modern hoods will have the .75 pitch
raid
Dad Photographer
OK. I can do this, but it won't be posted in the ad.
Travis L.
Registered Userino
Like others have said. The original hood is a pinch type. I've knocked mine off literally a dozen times, and I consider myself a pretty careful user. I now use the 43mm hood that came with my first version CV 35 2.5 Pancake.
I would suggest picking up a cheap screw in hood even if you do get the original.
raid
Dad Photographer
I will get a 43mm tilted and vented lens hood.
Highway 61
Revisited
Is this the type of hood you mean by "vented and tilted"? Is it Nr. 1?
Absolutely.
Bar8barian
xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
raid
Dad Photographer
Absolutely.
I will get one. Thanks for the tip.
raid
Dad Photographer
Hi Raid,
This might help you if you read this article :-
http://www.kenrockwell.com/nikon/rangefinder/50mm-f14-2000.htm#hood
Thank you. Will do.
