Lens Rubber Ring Turns White <Solved>
mark_pw
9:21 PM
I own a couple of Nikon and Leica lenses. Their focusing and zoom rubber rings turned white.
I reached the web and found several novice and DIY ways to clean the white stain, namely, nail polish solvent, vegetable oil, tooth paste, WD40... I dared not to risk my lenses. :bang:
Until recently I found a product made to clean the lens rubber by Lens Potion. http://www.LensPotion.com
I tried it on my Nikon and Leica. It works. :)
Result on Leica Summarit-M 90mm f2.5 rubber ring
See the result on removing the witness on Leica Summarit-M 90mm f2.5 :)
If oxidation is the cause then the whitening is superficial and can be removed with a soft toothbrush. Solvents, or even water, are entirely unnecessary. I just brushed my Zeiss Distagon 21mm in Contax mount to a black lustre. Looks brand new in 120 seconds, no cost, no residue!
I second Mothers B2B,
I've used this stuff on everything from old motorcycles to camera coverings and lens rubbers. It's good for getting a grip on dirt as well recently cleaned my 35/1.4Ai rubber that was mostly dirt with a little bloom.
Believe it or not, it also works on the quick-wind lever of Leica R7. I think it's coated by a think layer of rubber.
