Roger Hicks
Dear David,Hi,
This is Kodak's opinion:-
Regards, David
Well spotted!
Dear David,Hi,
Regards, David
Regards, David
I have not seen every Kodak catalog ever, but from the ones I have seen, the VPK came with an achromatic (two elements, one group, meniscus) lens. ...
Being Cooke triplets with one group consisting of a cemented doublet. Tessars are stunning at f/6.3; often good at f/4.5; usually not too bad at f/3.5; and rarely any good at all at f/2.8 (or worse, faster).
As I said earlier, It's when you want a wider angle or a faster lens that you need more glasses.
A lot depends on what you mean by "about the same". If you mean "perfectly fine on LF, just as all but the worst f/2 lenses are perfectly fine on 35mm", well, yes; but then again, you rarely enlarge 4x5 inch to the same extent as 35mm. I have an f/3.5 300mm Tessar which is great on 5x7 inch, but it's not in the same class as an f/6.3. And on 35mm, comparing apples with apples, I stand firmly by my original assessment.An F4.5 large format Tessar is about the same as an F2.0 35mm. . . .
Hi all,
I've been doing some reading about microcontrast and 3D pop lately (I know it's a controversial subject, so I don't intend to start a flaming war). One of the things claimed was that the least amount of elements in a lens usually leads to more microcontrast and real-life likeness and pop, albeit with less corrections.
From my own experience, from every single lens I have tried over the past years, Leica and Zeiss lenses always had an edge over everyone else's (Nikon, Canon, Zuiko, etc.) and older lenses (at least amongst those I have tried) tend to have the most microcontrast. I have seen this the most in a few lenses I have owned: a Summaron 35mm 3.5, the Summicron 50mm 1st version Collapsible, but also modern Zeiss glass and old Sonnars. I know that all of these have much fewer elements than, say, modern SLR lenses (some of which, particularly zooms, have up to 20 elements).
So I was wondering, what are the very simplest designed lenses? As I said, I have no intention to start a flaming war about optics theory, but I really am wondering if for my style of photography there might be some gems I have never heard about.
... The least amount of elements that are well corrected would be again in LF, an early landscape lens, which at first (1840s) were a cemented doublet achromat, then later a triplet single group (Dallmeyer 1860s). But they were slow.
A single meniscus will have a lot of chromatic aberration. For small format (35mm) they learned quickly you need a lot of elements to correct all the aberrations. ...
Not least because it was cheaper... . My impression is that both panchromatic and ortho film was available with a lot of amateurs likely to keep using ortho. . . . .
Ilford Ortho Plus (formerly Ilford Commercial Ortho) is still available.When did the last pictorial Ortho films vanish? By the mid seventies at least Western Germany was strictly Pan film, with all remaining Ortho films high contrast specialities.
