Life with the new Bessa R2
JohnM
11:02 PM
Hudson Valley, NY
I've had the new Bessa for almost two weeks and have managed to run a few rolls of film through it. My thoughts are distinctly non-technical - this is the first interchangeable lens rangefinder I've owned.
Ordinarily, I tend to accumulate equipment slowly - in this case, I had the chance to add two second hand lenses to the new CV 35/2.5 I bought with the camera. Having the three lenses has added some extra stuff to get used to, but it's a good problem to have.
The camera itself - I love it. The camera could be a smidgen larger for my tastes, but my hands are getting used to it. The viewfinder is bright compared to the compacts I've gotten used to - no comparison. Nice to have the 1/2000th top end although I haven't even come close to needing it. The film window in the rear door is handy for an absent-minded sort like myself. The rubber body cladding is tough and grippy.
Gripes - The film rewind handle is a bit strange and will scratch the body if care is not taken. I have the olive body and while I like the look of it with a silver lens, it tends to attract too much attention - I was asked at least three times if it was a military camera. Also, having had the chance to look over a black-bodied R2, I tend to think the splatter-paint would wear better than the matte olive.
The 35/2.5 - The rangefinder I was most used to was the 40mm Oly RD, so I figured the 35 would be what I would be most comfortable with. I just wasn't though; at times, it was too wide and the 50mm was more useful and at other times, it wasn't wide enough - such is life in the middle of the road, I 'spose. In its favor, it is a nice, sharp devil and it is truly compact - I need more time with it to decide whether I can find a comfort zone there or whether I should drop down to the 25/28 range.
The 35/2.5 - heard a lot of good things and a lot of bad things about this lens. Speaking as someone who likes to take pictures and hates to talk about pincushioning and the like, I really like this lens. Much more solid than the 35 and balances the camera out - the focusing tab is much kinder to clumbsy paws like mine. The 50mm focal length fit nicely with the way I tend to see things - all in all, a nifty piece of work and I recommend it.
The 90 APO-Lanthar - gripes...it's not really fast enough for indoor work unless you're loaded with light. If that's your preference, the 75/2.5 is a much better option. I would have bought the 75 if I hadn't lucked into the 90. The lens also takes on a probe-like look with the lens hood attached - it ain't discreet.
That aside, wow. Get this puppy outside and it is a gem. It is just sharp as a tack. It took a little getting used to the frame lines with the unmagnified image, but that becomes second nature quickly. Simply put - it is the sharpest lens I've ever used. It might actually make me look good one of these days.
To sum up - it is a luxury. The quicker 75 is probably more practical and it was my intention to use the 90 on vacation and then auction it off in favor of a 75 - now that I've used it, forget it. I'm keeping it and I'll worry about a 75 down the road.
Some other thoughts -
Get the Bessa case. Not the greatest piece of craftsmanship, but it does the job and the half case give the camera a little more bulk in hand.
If you're considering a new R2, it might be worth getting a move on. I was at B&H this morning and they appear to be out of stock.
Finally found a place that offers a reasonable photo CD with developing. For $10, I can now get negs and a CD - very handy. No shots with the 90 on the photo CD though - here's a shot of my daughter taken with the 50...she clearly has had enough of me and my cameras.
Welcome to the R2 user fraternity! Not only you will buy more CV lenses you will start to buy another R2 body and even the new R3! 🙂
Excellent review, John. Sounds like it's a keeper for you. No camera is perfect (not even Leica) but it sounds as if this one fits your needs well.
I've only had my Bessa R2 for a few days now and have had limited shooting time with it. Developed my first test roll of Tri-X tonight. I really like the way the camera feels in my hand. I've heard much about the 'loud' shutter but it doesn't seem that loud to me. Probably quieter than my OM-1's and they're not particularly noisy. Not Leica quiet, or even Canonet quiet, but not bad.
The built-in meter seems easy to use. Very bright, easy to see readouts.
Like you, I have the 90mm Lanthar. It *is* a sweet lens. At the wide end I'm using the CV21/4. Challenging but interesting. My main lens is the Summicron 40mm from my ex-CL. I use the 35mm frame for it.
My only niggle about this cam is how the lugs are situated at the front of the body rather than at the sides. It gives the cam an uncomfortable back tilt when you carry it around your neck. Most of the time I'm carrying it in my hand and it's in the bag when I'm not using it, so this shouldn't be a major problem.
I love the hinged-back film loading. After years of SLR cam usage, it's so totally natural I can load film very quickly. The brightness of the VF is a pure pleasure.
All in all, this is one of the nicest cams I've owned and I expect to use it a lot.
Thanks again for your assistance in getting this little black beauty, John! I guess that makes us kinda like Bessa blood brothers or something 😀
Gene
Re: new lenses - it could get ugly. If they make it, I will need it.
Hey, one question for the people used to toting around multiple lenses - what do you use to carry the camera and lenses? My SLR case doesn't really do the trick and the retro case I've used for my compact rangefinders is impractical. I was fumbling and juggling all weekend.
I'm glad it worked out, Gene!
I feel like I bonded with your camera in the hour or two I had it before it disappeared in a box bound for Canada! Pass along my regards to it ;-)
john,
i use a small tmrac case, the traveller. i don't think they make it any longer, i checked their website and they only have zoom travellers and they are very different from mine.
anyway, it is a small case that holds one body and 2/3 lenses.
when walking around the camera is on a wrist strap and the extra lens/film/etc is in the bag which is swung around to my back.
when i'm not shooting, all goes back into the bag.
i would think you should be able to find a similarly sized bag if you wanted.
at home both cameras and 3 lenses sit in my larger padded canvas bag.
i normally go out with one body and tops, 2 lenses, unless i'm on a misson and then it all comes with me.
joe
I use a 10x15cm (?) Zing bag that I can hang from my belt. It usually holds an extra lens, a mini tripod, a remote release, a little towel, and 5-10 rolls of film. If the xtra lens is my J-9 85/2 than there's no extra space left for other items (like sunglasses) but if I put the J-8 50/2 or CV 25/4 as extra lens in the bag there's plenty of space for more items (for instance sunglasses, but a smallish extra lens could go in as well).
The Zing bag has a rip cord to open and close it, which is very convenient. The bag itself is made of neoprene or such and is very flexible. Its size looks small but it can hold a lot of items.
I find the Zing bag more convenient than a belly pack but on holiday I usually opt for such a belly pack. First and foremostl I can keep it in sight on my belly so pickpockets (they have a nack of singling out tourists) won't be so quick to steal my things. In my own hometown I know what to look for and have much more confidence they won't rifle through my Zing bag.
I use a Billingham L2 if I am doing a whole day shoot where I bring along 2 lenses and bodies + films. Otherwise I use a Crumpler large digital bag for just a body and lens for leisure shoot. 🙂
Re: Life with the new Bessa R2
Cute shot of your daughter, John! And a nice demo of the oft-maligned 50/2.5. My most recent lens purchase too...
You might consider the Bessa Grip, which adds a little to the right side, or the Trigger Winder which also incorporates a grip. The winder of course adds some depth to the body as well as the handy bottom-mounted winder. I have one of these on my Bessa-T.
One additional feature of either is in offering two more strap lugs posititioned a bit further to the rear for better balance. Both the lugs are positioned on the right, with the second lower one for carrying the rig vertically from that side. I like that.
The original lugs are a bit more forward on the body than seems ideal. This is a reminder of the body's origins as an SLR. 🙂
I don't usually take along any additional lenses except for extended outings. I do like those velour pouches with the drawstrings, though. I can slip the additional lens in a pocket to balance the hand-held incident meter in the other pocket.
Exactly what I would say about my R2 John. You were asked about the olive finish, when I was on vacation I was standing next to a man taking a couple shots of my son, and when I lowered my camera he was all a buzz about how nice a camera it was, "That's a German camera, they are great." I gave a quick explaination and then had to move on following Sammy.
I too started with a 35mm lens and felt a little lost with it, and wanting for a 50mm. I will say that I have learned to like it a bit more as Sammy has gotten older. When your daughter starts to be mobile, you will find that your are chasing her around more, and wanting to stay closer to her. That wider view will become an asset.
I have an Adorama Slinger bag. It has plenty of room for a small kit and your personal items (wallet, keys...) and carries nicely on your back.
I use a modern Nikon compartment case with Velcros Dividers to carry most of my outfits. It holds the camera with lens and three lenses. I do not think Nikon assigns numbers like they use to for their cases. I have the original leather 1950's compartment cases for the Nikon RF and the Leica M3. The M3 case has bayonet mounts for the lenses. Each is in top condition, but I end up using the modern case almost all of the time. The latter is convenient.
