Godfrey
somewhat colored
Incident meters are designed to be read pointed at the light source for your main subject, meaning if the subject is in direct sun or shade, the meter's disc should be in the same light....
No. You point the incident meter at the camera from the position of the subject, not at the light, to get the correct reading. To wit:
Sekonic L-478 Owner's Manual p23:
4-2-1. Measuring with Incident Light Function ...
Use either extended or retracted (flat) lumisphere to measure incident light. Point the lumisphere at the camera (lens optical axis) from a position close to the subject and then measure. ...
Sekonic L-398A Owner's Manual p6:
Incident Light Measurement
c. From position where subject is to be measured, point Lumisphere q in direction of camera. ...
