Linhof Technika III 5x7
V
varjag
Guest
Hello,
I'm considering getting this camera with Angulon 120 (no cam). It's worn on exterior but claimed to be with no light leaks and in working condition. The seller wants $900 for the kit.
Is that an OK price? I also heard that the III is not fully compatible with later versions. Does it require special film holders?
Some III's have a German style metal holder back - but most have a "international" back. In general, the III was released immediately after the war and discontinued in 1956 - it is mostly not part interchangeable with later Technikas. Spare parts aside even lenses cammed for the III are very rare (and supposed to be cammed to match one particular body) and you might never find a cammed lens that is a nice match to your camera. Effectively the configuration you've been offered is just a nicely collapsible but otherwise rather plain view camera, with a useless rangefinder. $900 for a worn 5x7 view camera from around 1950 would be a bit too much.
It's not a bad price, but not great. If it's the one that's been sitting on
the 'bay for a while it has the older style back for the metal single sheet
holders. Not so useful as-is, and not that cheap to replace with he more modern back either.
-Brian
(btw- a working RF is nice to have, but the closest I can get to shooting handheld with my 5x7 Tech IV is with a good monopod- these things are HEAVY!)
The ST-III was strange. They made it for a long time with a lot of changes. The early ones were mostly almost one offs, the latest ones were very similar to the IV. I had a 4x5 that the factory said was made in 1957* and about the only noticeable difference between it and a IV was that it still had the old style lens boards.
Because of that, early models are terribly hard to find parts for or get repaired. If it does not have the international (Graflok) back and the dished front panel, I would avoid it except as a collectors item.
* you will read that they quit making the III in 1956, I have, but in fact the IV was announce at Photokina 1957 and most likely did not hit the streets until 1958. The IV was probably the best selling Super Technika, there seem to be a lot of them out there despite only having been made for 4 years. Although if they had continued using the same naming convention the ones they currently sell would still be IV's as they are less different from a IV than the last III was from the first III.
As to what it is worth, there is a very strange thing about asking such questions of a bunch of folks who would like to have such a camera. If it is a bargain, you can bet it is gone before you get your first answer. Actually, what anything is worth is what YOU are willing to pay for it. There are no fixed prices on collectables there are too many things going on there that have nothing to do with the item itself.
Thanks for responses.
Yes, I understand that if the price is good and it's still unsold there must be a caveat, that's why I asked here. With the information provided here, think I'll pass.
I really would like any kind of 5x7 field camera.. not planning for an extensive system, but that's about my budget. I used a Russian FKD 13x18 back in 2005, but would rather prefer something a bit less wobbly now.
FYI- don't get confused too much with the differences between the 5x7 and 4x5 models. There are a LOT of changes between a tech III and IV 4x5 camera, but not much between the III and IV on the 5x7 side- it's actually pretty hard to tell the difference between a late III and early IV 5x7, open or closed.
(with the late III 4x5's, the case looks about the same as the IV's when closed, but when you open them up it's a completely different front standard and rail, different lensboards too. 5x7 III/IV/V all seem to have the same board)
-Brian
