LTM to M adapter recommendation
Jonnyfez
7:35 PM
Hi all,
I have a new (to me) Elmar 2.8 that I want to put to use on my M2. I see a number of low-cost adapters on eschmay. Is there one that is recommended - or one to definitely avoid. I want to keep the cost down and not get a Voigtlander or Leitz. Rather put the money into getting the lens CLA'd.
Thanks in advance.
Jon
I use the Voigtlander adaptor too, and I have to say that it does a perfect job. It's very well made. It makes sense to buy one for each LTM lens that you plan to use regularly on an M-mount. Just leave it on the lens all the time.
It makes sense to lurk on eBay and here for a while for Voigtländer and Leica adapters; if you have the time, you can spend a while lurking for steals and saving a fair bit of money on known good adapters.
I went with the Voigtländer adapter as well and consider it a good value in that it hasn't caused a lick of trouble and I had not even thought about it for years until just now when I saw this post. 🙂
You can get a voigtlander adapter for as low as $25 if you look around hard enough.
I have bought two of them for that price, a 35mm and a 50mm one.
