NickTrop
The Lynx 14 is one of my favorite cameras (perhaps "the" favorite camera). That said, straight up, its wonderful sharp, contrasty, super fast lens is absolutely flare prone. Recently, I thought I might try a Hoya SMC Pro 1 UV filter on this camera. This is a thin filter with 12 layers of coating on both sides of the filter. The ad said (and, sorry, I can't find the link to it, now) it helps reduce flare. This is a pricey filter (seems to run around $60 plus on the Internets) but I snagged a new one on eBay for around $30. I bit...
I just got my first roll back using this filter on the Lynx 14. Though there is debate around whether filters help flare at all, and some will tell you they add flare because you increase surface to air instances, it really seemed to help get the flare under control judging from my first trial.
Granted, I only shot one roll using the filter. The roll I shot was indoors. But with the Lynx, at wider apertures pointed at a light, the flare would really predominate under ordinary circumstances. After a little while you know your camera. I know when I point this at an object with a light-fixture in the scene, the light will usually produce flare. And that was not evident on any photo I shot yesterday, except a little bit on one.
Next to do an outdoor test with sunlight...
File this under FWIW... but if this filter broke, I would buy another one for the Lynx immediately. Worth every cent, thus far.
