M-Hexanon 35mm f2 (not the UC in L-Mount)
reala_fan
4:59 AM
Ok gang...
I have my CV 35/2.5 PII and I must say, it has proven to be a very nice, sharp daytime lens.
I also have an M-Hexanon 50mm f2.0 and I think it's a fantastic lens.
So I am looking for opinions here, please...
Would I love the M-Hexanon 35mm f2.0 more than the CV 35/2.5 PII?
Or should I stay where I am?
Let's don't consider the "1/2 stop faster" of the M-Hex 35 as a factor...just clarity/sharpness.
If you have the lens in question and could post some examples. I'd appreciate it.
I have long considered the same choice. The M-Hex 35/2 is the only M-Hex lens that was designed by Konica from scratch. Outstanding performer, in every respect.
In the end I kept the PII as day-time, high-performance, "clean" 35. Due to size. In my eyes picking either is only a matter of size, speed, price and filter size. And getting a good sample. If you are happy with your PII, I suggest to keep it. Maybe look for a second 35 with different character.
Here are samples in the flickr M-mount forum:
http://www.flickr.com/groups/86731438@N00/pool/tags/KonicaHexanon35mmf2.0
Roland.
I have both. Well, my CV is the original Pancake one. I did try PII and a Classic but somehow P is the one I prefer. They say they should all be the same optically, yet ....
Anyway. M-Hex 35/2 lens is very very good. In many ways it reminds me of Summilux ASPH 35, just not 1.4 and not ASPH. Yet shape, and optics are very similar.
I like it better than UC-Hex - as it focuses closer and has much nicer bokeh. I did have some pics posted from it a while back in some thread. Here are a few I can find right away:
Yet it's more expensive and pretty hard to find. A bit larger than CV lens.
Personally, I dont use mine as much as I should, but cant bring myself up to sell it - it's that good and rare. I'd definatelly recommend Hex M35.
the Hex is HUGE compared to the skopar.
It is built better, although the skopar is not bad.
The image quality of both is excellent.
For me, it's a question of
price
speed
bulk
build
I decided that the almost-one stop faster of the hex was important and when I was proposed a good deal by a fellow RFFer, I went for the Hex.
BTW, even on paper, f/2.5 is more than one stop away from f/2, and I read somewhere (yeah, on the web, so it could be bulls) that the sokpar is closer to f/2.8 than to 2.5.
At any account, f/2 is critical for me, because it allows me to handle most indoor situations @ 1/30 sec with tri-x...
Not to go off topic (much), but I faced a similar choice when I saw the M locally at a very reasonable price. I already have the CV 35/1.2, which is a fine lens and not much larger than the Hex. In the end, the $100 more I paid for my used 1.2 lens seemed the way to go.
My Hexanon was the lens always attached to one of my M6TTL cameras until I got an Elmarit 28mm and a 'lux 35mm. Then, it moved to my M4-2, and I use it still a lot, as it's fairly large, yet easy to handle and sharp as a tack wide open.
The only "problem" is that, when turned to infinite, the rangefinder coincident images don't quite match. Otherwise, it's a great lens. Most of my 35mm shots were made with my Hexanon. It's traveled with me all over the place, so I can attest to built quality.
I bought it pristine... but it ain't pristine no more; there are some small spots where the paint has fallen. But then, now it has a lot of character. 🙂
I had this lens for awhile -- I bought it when I was living in Japan. It is excellent and I only sold it because I finally decided to buy a 35/1.4 ASPH (back in 2005 I guess). I tested them together and could not discern any notable difference other than the Leica being one stop faster. The 35/2 M-Hexanon is an extremely good lens...the only issue is that there are a number of extremely good 35mm lenses between f/2 and 2.8 these days! The Summarit 35/2.5 is also extraordinarily good and much smaller, the ZM 35/2 is supposed to be superb as well, though I have not used it. Then you have the 35/2.8 ZM and the Voigtlander 35mm's...it leaves the 35/2 M-Hexanon as an unusual choice. But if you go for it, you will not regret it...I have had the 35/2, 90/2.8 and 50/1.2 M-Hexanons and all of them were every bit as good as their competitors.
Filter size?
Filter size?
Hey guys, what filter size does the 35mm use? The 50mm uses an odd size (40.5mm) but the 28mm and 90mm uses 46mm filters (ah, a bit more normal).
Would be nice to know, before an eventual purchase!
Best,
David
Make what you will of the following:
I have no experience of the 35mm Hex., but I have experience of the 35mm Colour Skopar, and the 50mm f2.0 Hex. on the M8.
When I bought the Colour Skopar I thought it was a nice, sharp, well behaved lens and it served me well for some time until a change in my way of working made me doubt it's [particularly] far distance rendering. The definition from the 50 f2.0 Hex. always impressed me as superior to the Colour Skopar and of a very high quality.
I bought the Zeiss 35mm f2.8 C-Biogon, and I am amazed by how good this lens is --- a lens for life! I really didn't expect the C-Biogon to be even better than my M-Hex. but it is, and has become my lens-cap lens.
I don't know how the two Hex lenses compare with each other, but given that you don't seem to be a fast-lens obsessive I suspect you too could fall for the many charms of the fabulous 35mm C-Biogon; it might be a better option for you than the 35mm Hex..
.............. Chris
