M2 rangefinder patch = 135mm
los
5:47 AM
just wondering if anyone has ever heard of this, or if i'm way off. the 90mm frame lines are only a little larger than the rangefinder patch, so it would seem likely.
You can think about it like this:
Imagine 135mm framelines. Their long side is the same size as the short side of the 90mm lines.
Best,
Roland.
rowland, i need a little help with that. do you mean that the vertical frame lines on the 90, are the length of the horizontal frame width on the 135?
