airfrogusmc
I don't use LR or SE and both came with my camera. Photoshop for me. CS6.
Leica M is a great camera for working quickly. That's big part of why I use one.My need to work quickly is not a put down of the camera, only an acknowledgment of the challenge involved.
Blowing of highlights is a metering issue, given the later comment about when working quickly. However, you're correct that if holding sky means shadows aren't recoverable then there is a lack of dynamic range.
I've only ever used a 262 once, but I understand the 240 and 262 have more DR than the m9.
Mime
no, here is how OP described his issue:
''If the sky is right then the ground is so dark that recovery is difficult. If the ground action is right then the sky is completely white. ''
thats not a metering issue. thats lack of dynamic range. trying to treat this as a 'user' issue will only frustrate the user. there is no amount of user machination or techno-babble that is going to change this result. see it for what it is and move on.
This is why I won't be buying the lcd'less M. The lcd is not just for chomping but this is precisely why it's useful. Check the histogram etc.. Not sure about M cameras but on my D4s and D750 I have the preview set so blown highlights are easy to see (blinking highlights). Then I adjust exposure accordingly as there is no simple rule of drop down 1 or 2 stops, it's a situation by situation matter.
One could just shoot and let raw handle mistakes But I prefer to nail exposures at the time, as best I can so there's less agro in post 😉 ymmv
The dynamic range of the M240/M262 sensor is really good. If you constantly blow the highlights in the raw data then this is a user error.
This would help us to check whether this very M262 might not have a faulty sensor or CPU indeed.Perhaps it would be helpful to provide a download link to two or three photos (in RAW) which show those issues.
As.someone old enough to have used film for longer than digital, lots of blown highlights seem a poor payback for noise free shadows.
Aye, but that was the point I was making. These newer sensors are able to pull data pretty cleanly from the shadows - so I would err towards underexposure to preserve highlight detail. Knowing that the shadows are recoverable (and still quite clean).
tom, did you not read what OP said and what i quoted? if you did, and if what he said was correct, then it is a DR issue because he is either unable to recover highlights if low light areas are properly exposed or unable to recover shadow if highlight areas are properly exposed. there is no other explanation other than a faulty camera.
