M7 + 21mm ASPH + Flash
RichardB
6:56 AM
How have others done this arrangment and what units have you used that allow the TTL features of the M7 to be used? I have the SF24 but obviously not only does it not have 21mm coverage but it must mount where the 21mm finder goes. Since I have 0.85 M7, I need to use the 21mm finder and anyway even the 0.58 finder does not have 21mm frame lines.
The only solution so far that I have come up with is the Metz 76 MZ-5 which has a 20mm coverage and a bracket for off camera flash. This looks like a big unit more suitable for wedding photography than shooting indoors with K64 but unless someone has found an alternative solution, this may be what I have to do.
Any experience that you have had in solving this problem will be appreciated. Thanks in advance for your help.-Dick
