jaapv
RFF Sponsoring Member.
Sounds like a reasonable summary of the thread....To me, it seems very likely the OP picked up a couple bargain bin lenses that are slightly off. His M8 is probably perfect wrt mount and sensor distance.
Well said! 🙂And please, let's cut the crap with CoC:s and all that. It doesn't belong in this discussion. 🙂
I wouldn't trust the mirror thing too much. The camera body has a thickness, so when you focus on it, it will induce a slight mismatch to the "2" meters reading on the scale.do all 3 of your lenses behave the same with this simple test: http://nemeng.com/leica/024b.shtml ?
Yes, I think so. It definitely reaches infinity wide open, even if the DOF is so deep that I don't know if it's sharpest a little closer to the camera. And since this lens also shifts focus, it's definitely at infinity at f/2.8.
On the other hand, the borders are quite unsharp. But I wouldn't expect them to be sharp when wide open at infinity.
The camera might have been dropped, because there is a tiny crack in the RF patch window on the front
My conclusion is that the CL lenses are calibrated for a slightly different film-to-flange distance.
Why repair something that's probably not broken? Hundreds of dollars down the drain. No thanks.My conclusion is: send the camera for repair, before investing in other lenses.
Thanks for a good answer! I'm gonna try the shimming, but my problem is that I have no clue of how to disassemble the lens: http://www.rangefinderforum.com/forums/showthread.php?t=85645I will try to answer your question since everybody is either telling you crap about depth of field or telling you you are smoking crack for trying to use the lens on a M8. You have one of two problems as I see it. Hope for the first problem.
1-The entire lens assembly is shimmed wrong- Easy fix. It appears to have too much of a shim between the lens block and the helical mount. Remove the thinnest one. It needs to move only a very miniscule amount judging by your picture. It is possible too that there is something else (dirt, what have you) between the lens block and the helical mixed in with the shims. If you fix it this way for infinity and it is way off up close (focussing behind the object), go to #2 and say your prayers.
2-It is possible that someone put the lens back together wrong. If the rear elements are too far from the front elements (too much shim perhaps) it increases the focal length of the lens and will make infinity focus farther than it previously was. Another possibility is one of the elements could be off if it wasn't properly reassembled.
So hope for #1. If it is #2 it will probably have to go to a professional to get it fixed. At least you have a digital camera to check it on!
I am sure someone will point out some heinous error on my part in the above directions, but I am just trying to help.
