jaapv
RFF Sponsoring Member.
Nicely argued Philipp. I never thought of the "same lens on different bodies" difference. But it is true, albeit with a 1.33x diffference it is just a matter of getting used to it I feel.
greggebhardt said:10mp will be more than enough and it does not have to be full frame either. The has been argued so many times. 35mm is NOT the Gold Standard and IS a "compromise".
Every thing is a compromise!
Mark Norton said:Marco, September 15th is the day we find out that the new Tri-Elmar is not €2500 and the M8 is not €3800... 😉
Nemo said:Calculations based on 300ppp assume that 6 lp/mm is the higher resolution of the unaided human eye at optimum distance (25cm or a bit more), at best (the average value for adult people is 3-4 lp/mm). Higher resolutions on prints have details that cannot be seen.
Sparrow said:Yes but in reality I can see a single blond human hair on a black sofa at 3 metres
Nothing…….sadlyNemo said:What was you doing last night in that sofa?
That's because it is a single hair. If it was hairs laid out next to each other at six hairs per millimeter (commonly called "carpet"), you wouldn't be able to tell them apart anymore.Yes but in reality I can see a single blond human hair on a black sofa at 3 metres,
Sparrow said:Yes but in reality I can see a single blond human hair on a black sofa at 3 metres, and if I can see it I want to be able to photograph it!
I understand that but that hair is less than the one minute of arc that is the theoretic limit of the eye, therefore applying that as an upper limit on a print is equally spurious.rxmd said:That's because it is a single hair. If it was hairs laid out next to each other at six hairs per millimeter (commonly called "carpet"), you wouldn't be able to tell them apart anymore.
This is one of the problems with this definition of resolution (another is that, as with lenses, resolving power varies with contrast).
Philipp
jaapv said:How often do you view A3 prints at 25 cm? 75 is more near the mark. That would reduce the resolution to 1-2 lp/mm.
How do you know?jaapv said:That is why it is not transparant 😉
Sparrow said:How do you know?
No my exposures are pretty decent actually, that’s my gaol anywayjaapv said:Are you writing this from prison for indecent exposure?
jaapv said:Well, I cannot, but unfortunately my wife can, and at 10 metres as well...
Sparrow said:No my exposures are pretty decent actually, that’s my gAOl anyway
