crist
Crist
is the same sensor for 2 cameras or diferent? In high iso perfornance is m8.2 best to m8??
jarski
same sensor in both.
crist
Crist
oh, thanks jarno!!
Rob-F
Likes Leicas
Given that the sensor is the same, I wonder if there are differences in the image processing of the two models that might give different results.
swoop
There is absolutely NO image quality difference between the two sensors.
Also, the M9 sensor is pretty much the same sensor design but larger and has better processing.
jaapv
RFF Sponsoring Member.
And a different Bayer filter, which makes quite a difference.
proenca
Proenca
100% to everything that has been said :
M8 vs M8.2 : image quality is absolutly the same. No diference.
M9 vs M8's : same sensor, different size, different bayer filter, different micro lens alignment - which all contributes to a very different signature and very different files.
