Freakscene
Obscure member
Thanks for the heads-up on that one. I do not foresee a need as I have the upgraded Leica sensor/circuit board, but it is nice to know.
I wonder why Jadon stopped the service? The posts he had of the sensor he modded look pretty good to me.
My guess...high cost and risk. I suppose that many M9/ME owners -like myself, opted to trade their disabled cameras, instead. Cheers, OtL
It’s not too risky, but it’s s l o w. With a small team I’ve now done several, and it takes a g e s.
And every now and then one has some slightly different hardware and won’t let you flash the new firmware in easily. And without the new firmware the colour (M9) or tonality (MM) is off.
And sometimes the new sensor cover is the wrong thickness, but just by a minute amount. Especially if you’re using the inexpensive pre-cut covers available online. But it still needs to be trashed and replaced If it is the wrong thickness.
And sometimes the old glue won’t let go, and you have to grind the old cover off under vacuum.
And if you get dust under the new coverglass you can’t remove it without removing the cover and putting a new one on.
And on and on.
I would say anything under $US2K is a rush job, and they definitely aren’t changing the firmware for you.
