tlitody
Sure, if the lens is the limiting factoring. Shooting with faster film though, grain often limits the amount of perceivable detail. Once you hit that point, MF wins.
I can see your argument if we're talking about using a tripod with iso 50 or film but with 400, I don't think lens resolution is necessarily the gating factor.
Lens resolution is a red herring. It's worked out using very high contrast ratios. i.e. 1000:1. In the real world your subject, in nearly all cases won't have alternating black and white lines with the sort of lighting needed to produce measurable 1000:1 lighting ratio. Infact the edge contrast of most details in your neg will have much much lower contrast. Maybe only 1.6:1 which is what Fuji use in their data sheets. So a film capable of 125 lpmm at 1000:1 is only capable of 50 lpmm at 1.6:1 contrast ratio. And that means the high resolution figures banded about don't exist in the real world. And your MF lens gets as much resolution on film as your small format lens does because thats all there is in the subject and thats all the film is capable of at those contrast ratios.
So the idea there is more on small format film to enlarge from is wrong in most cases.
