Here's what you do:
- Go to Ebay and find yourself a copy of the Kodak Pocket Photo Guide.
- Put it in your pocket; use it for every photograph.
- Shoot a few rolls of film in varying light conditions.
- Take notes as you shoot.
- As soon after every roll of film as you can, process the film and examine the negatives carefully.
The
Kodak Pocket Photo Guide contains calculators for exposure based on scene type. There are standard light calculators, available light (darkness) calculators, close up exposure calculators, etc. The calculators have a description of the scene type and give you a few choices of shutter speed and lens opening to match them. Pick the ones that are closest to what your camera has to offer. When you finish and develop the roll, be sure to note which are the successful exposures, what the scene was, and what settings you used.
After a few rolls of film, if you do this, you'll have the exposure settings for most scene types in your memory and won't need to bother taking out the guide or writing down the exposures. Keep the
Kodak Pocket Photo Guide in your bag for easy reference in case you are unsure or encounter a new situation.
I started photography with an early Argus C3 and a 1949 Rolleiflex Autocord, both loaned to me. I didn't have an accurate exposure meter for years—all the ones I had access to were old and mostly inaccurate. I used the recommendations in the film box for exposure. Later, I bought a
Kodak Pocket Photo Guide because it had more than the exposure sheets with the films and cost me $3 (a lot of money when I was 13, but much less than an exposure meter).
Because of the analog calculators and the "scene description to exposure" mapping in the Photo Guide, to this day I can generally set the correct exposure just by looking at a scene and setting the numbers on the camera. I don't know how I remember all the combinations, I can't recall them consciously, but I can always look at a scene and know about what to set the camera to.
Give it a shot and forget debating Sunny 16 vs Sunny 11. ;-)
G
Ok, pardon my dumb question folks, I'm trying to ween myself off a meter here..
Sunny 16...
Say I'm shooting ISO 400 film. Aperture set at f/16 and it's full light out side.
You say shutter 1/400.
I say my film cameras are in full shutter speed stops, so it goes 1/250 then 1/500.
How does this work? I can't select 1/400. If I select 1/250, I'm basically 2/3 stop overexposed. if I select 1/500 I'm basically a 1/4 under exposed. Which is best?
