Minolta dynax 9 built in flash problem.
geordiefred
2:06 AM
England, UK
Anyone who has used the Dynax 9 come across a problem/fault when the built in flash is raised, it locks the camera ? To rectify, lower the flash, switch the camera off, then back on and it will work normally.
Any views and comments as to the reason will be appreciated.
Thanks.
No feedback from members, but believe the fault is in the built-in flash circuitry. It is not charging the flash, and therefore prevents the shutter button being depressed. That is normal when the flash is working correctly. Until the flash is charged and the lightning symbol appears, you cannot take a photo. I thought I was going to get a bargain Dynax 9 for about £60.00, but the thought of a professional repair has put me off.
