tenter10
hello my fellow photologists, can anyone tell me, if my meter has had it do I need to keep the battery in for any other function . I thank you jack
sig
No you do not need to keep the battery in (except if you shoot in auto exposure mode, but if your meter is dead it will not work anyway)
andredossantos
Also, I've found that when using a silver oxide or alkaline battery, the meter badly overexposes (the camera was made for mercury batteries). Maybe its just my camera, but something to watch out for...
tenter10
minolta hi-matic 7s
thank you my friends I noticed when I put a 1.5v bat in, the meter needle went right to the top and did not move. I am waiting for a light meter to come and I will try it on manual. Thanks Again jack
Gary E
Did you try to select the ISO/ASA under the lens? It turns on the meter (with lens cap off of course), otherwise it will look dead. As the others said, the camera will work on manual and not in Auto if there are not batteries. I've used the Wein cells with some success, but they didn't last too long.
Trius
Waiting on Maitani
You need a battery of the same voltage as a mercury cell, which was 1.35v, not 1.5 in silver oxide. I use zinc-air hearing aid batteries, which are 1.4v (close enough) and add a spacer, if necessary as those cells are not wide enough diameter.
The ohter option is to use a Wein cell. Those are quite a bit more expensive than the hearing aid batteries.
It's a nice little camera.
tenter10
I thank you I will try it on manual I am waiting for my first film to come back to see if my replacement of the light seals worked jackDid you try to select the ISO/ASA under the lens? It turns on the meter (with lens cap off of course), otherwise it will look dead. As the others said, the camera will work on manual and not in Auto if there are not batteries. I've used the Wein cells with some success, but they didn't last too long.
tenter10
gary e
gary e
gary e
I tried the asa move no luck.Did you try to select the ISO/ASA under the lens? It turns on the meter (with lens cap off of course), otherwise it will look dead. As the others said, the camera will work on manual and not in Auto if there are not batteries. I've used the Wein cells with some success, but they didn't last too long.
tenter10
trius
trius
trius
thanks I will go manualYou need a battery of the same voltage as a mercury cell, which was 1.35v, not 1.5 in silver oxide. I use zinc-air hearing aid batteries, which are 1.4v (close enough) and add a spacer, if necessary as those cells are not wide enough diameter.
Gary E
I removed all of the old foam seal and use it bare. So far, I haven't had any light leaks though I do shade it from direct sunlight. I think it's more of a dust seal than anything. To the suggestion of using hearing aid batteries, I'll give that a try.
tenter10
to all of you my meter arrived I think it is a dud?
Mr_Toad
Fluffy Marsupial
Hi, Tenter10,
May I ask what specific battery make and model you are using? I ordered a used Hi-Matic 7SII, and I am wondering if the same battery would have the same result in the the camera I get.
I'm new to this old camera thing, but it seems that different batteries have different affects on these old meters.
Thank you,
Robt.
Thank you,
Robt.
tenter10
Hi, Tenter10,
Thank you,
Robt.
tenter10
MateI am a novice for 18 yrs I used an instamatic until I got a SLR.I am only just getting back into rangefinders. My camera is the older 1966 7S.Go onto minolta hi-matic site and dial up matts classic cameras all the gel is there.
Jockos
The 7SII is also for mercury batts (http://www.jwhubbers.nl/mug/HiMatic2.html)
I use LiIon batteries in my 7 and simply turn the ASA to one step higher than normally to compensate for the increased voltage. Very simple fix
