NL2377
*scratches head*
- Local time
- 7:54 PM
- Joined
- Jan 18, 2006
- Messages
- 257
I've been wanting to get a j12 and bessa L for a while now, but after some research, have found that they most likely will not be compatible with one another. I Have also read that there is a possibility that some of the later J12s can mount some Bessas... so I have a couple of questions:
Is It possible to alter the Bessa L body in order to fit a J12 on it (IE relocate the meter without creating a substantial difference in metering (0r if there is a way to alter the metering circuitry to be more accurate with a 12 on?
What would happen if I were to include a spacer between the lens and the camera, just enough so that the lens would fit snug, but wouldnt make contact with the parts of the camera? Im guessing that focus to infinity would be lost, distortion would be higher, DOF would be shallower, and that the focusing scale would be off slightly, but my question is more or less by how much?
Are there any inexpensive alternative lenses (35mm or wider) that would fit the body better w/o modification and still allow metering?
Thanks for your help in advance. -Nick
