Modern Photography review of the Focomat IIc, 1974.
5:55 PM
Amsterdam
I found reading this quite interesting:
"The following unsigned review appeared in the now-defunct Modern Photography magazine, April 1974. The title of the review was 'The Most Expensive Enlarger We've Ever Tested.' I've edited it for brevity.
Manufacturer's Specifications: Leitz Focomat IIc Enlarger. Features: Accepts all negatives 12 x 17mm to 6 x 9cm (2-1/4 x 3-1/4 in.), cam-guided autolocus operation, parallelogram construction, rapid shift lens turret, equipped with Leitz 60mm Focotar and Leitz 100mm V-Elmar lenses, illuminated magnification scale, adjustable for easel thickness, Osram 150-watt lamp, red filter, filter drawer, heat-absorbing glass, adaptable to distortion-correction device, copying back for reproductions down to 1:1, white-surfaced baseboard and negative mask storage drawer. Price: $1,806 (with lenses).
If we had to name one enlarger that ranked first in design, quality of construction and performance, this would have to be it. The basic design concept, the fit and finish of the individual parts and the overall performance all add up to place the Focomat IIc in a category that is mighty lonely. There's only one enlarger in it, the Leitz Focomat IIc.
As a rule, we first discuss the enlarger under test in terms of its basic design. Then we talk about the various performance tests before making a final evaluation. But in this case we would like to reverse this procedure.
In terms of alignment among baseboard, negative and lens, the Focomat IIc tested out at nearly a zero discrepancy between all three planes. Actually a 1/16 bubble length (using our standard alignment tool) was detectable between negative and baseboard in the lateral plane. No detectable error was found in any other alignment measurement. To put this in perspective, we regularly run into 1/4-bubble length errors in all planes of many machines previously tested.
Illumination tests are designed to check evenness of illumination across the print area. The Leitz Focomat IIc with the 60mm Focotar in place checked out as follows: Corner-to-corner discrepancy--zero. That is, if there was a difference it was not readable on our Lektra PTM-7a photometer, and it is calibrated down to 1 /10 of a stop. The center-to-edge error was about 1 /10 of a stop. These are the best illumination specifications we have ever come across in our testing.
The Focomat lIc is a dual-format enlarger. While it covers negative sizes down to 12 x 17mm (Kodak Pocket Instamatic), it is basically designed for the man who works with 35mm and has a second camera using a larger format negative. It can be anything up to 6 x 9cm, but more likely it would be 2-1/4 in. square or 6 x 7cm ideal format. The 6x9 maximum capability, however, makes this machine especially useful in some professional graphic arts applications. It is autofocus for all formats.
The lamphouse looks like a simple spherical metal stamping. That's deceiving. Actually it is double-walled, providing heat insulation and ventilation. The inside is silver and the 150-watt bulb is adjustable over a short range. The lower section of the lamp-house is also double-walled with large vents to provide convection cooling through the lamp-house.
The entire head from negative stage upward can be removed completely by just loosening a knob and lifting the head. This facilitates cleaning, but basically it is to accommodate the accessory negative-tilting device to be used for the correction of converging verticals. This device was not tested by Modern's editors. Note that most enlargers made in Europe are equipped with this feature. Most enlargers made in the U.S. are not. And since we have never met a single serious photographer who uses this correction device, we feel that its elimination from enlarger design makes sense. In the Focomat IIc you can take it or leave it.
In order to appreciate this machine fully, you need only examine the details. The filter drawer, for example, is well made, slides in and out smoothly, but is prevented from being pulled all the way out by a rod with a gravity catch. It can be pulled out for installing filters. To remove it completely, just depress the catch and out it slides. The heart of the machine is the autofocus system. Let's trace the action of printing a negative. And let's start by removing the carrier. It is a large, heavily-built unit, hinged at the back. The glass plates that keep the negative flat are set into the carrier and recessed. They are held in place by chrome strips and a steel spring-loaded pressure arm. The front of the carrier has a lower lip and an upper hinged arm. We place the negative between the glass plates, close the carrier and slide it into the enlarger. It goes in on four tracks. A large pair of springs holds the carrier in place. The hinged bar separates the glass plates so that film may be shifted without scratching.
The opening on the carrier is 6 x 9cm. If we are using 35mm, we select a 35mm mask from the rack under the baseboard and slip it in place under the carrier. Ten masks are available to cover all possible sizes from 12x17mm to 6 x 9cm. Let's assume we are enlarging a 35mm negative. We have already set the collar at the base of the upright to the 35mm position to accommodate the height of the Leitz easel.
Now we shift the lens turret to the left to position the 60mm lens in the light path. This automatically actuates the Bowden cable which puts the proper cam into position. The enlarger is now in perfect autofocus throughout its usable range. To get the image size we need, just Ioosen a large knob to the right of the lamphouse and lift or lower as needed and the image stays in focus. The head is so well counterbalanced that the action is smooth, silky and effortless.
To work with the 100mm lens we just push the lens turret to the right and we are ready to go.
The price of the enlarger we tested includes an illuminated magnification dial that Iights up in the dark. Without this dial the price drops to a mere $1,730. Add $204 more if you want a Leitz 12 x 16 easel. One I accessory that we do recommend is the 35mm carrier with no glass on the bottom plate. It reduces dust problems. We don't know its price at this writing, but we consider it an essential adjunct to the Leitz Focomat IIc."
This is what I wrote about this enlarger some time ago:
"I like the IIc very much, also for 35mm work. The strong points of the IIc are the evenness of the illumination and the ergonomy the special 35mm carrier provides. When you intend to do 35mm work with the IIc this special carrier is essential. This 35mm carrier has only on one side glass, anti-Newton glass. The glass holds the negative flat in the same way the condenser in an Ic does, but it has the advantage that there also is a small clip that holds the negative in place. This clip is very convenient. It can hold in place a piece of film as small as the length of one frame. Now try to do that with an Ic.
When you want to print the whole negative with a black border, you'll have to file out the cut-out of the brass mask. The brass is 2mm thick. The filing takes some patience, but is not hard to do.
The 60mm Focotar is very good for prints up to 24x30cm. On prints of 30x40cm you'll notice a very slight unsharpness of the grain towards the corners, but the prints are nevertheless beautiful.
When choosing a IIc you should look for one with a filter drawer. The IIc is a bit too big to take off the lamp housing every time you change the filter.
I love my Focomat IIc as much as I love my Leicas. It certainly is the most beautiful enlarger in the world."
Erik.
I use mine regularly. It is the ultimate extension to my Ms and their
Raison d'être.
Yes, the evenness of illumination is legendary: my Xpan prints are the living proof. Even the corners are sharp and evenly lit.
Yes, the IIc is what holds all my Leica Ms, the lenses and my Xpan together. It is what makes them all sing. Mine goes to the grave with me.
Nice to get to read that old review. Thanks.
Then again, I really don't need more enlarger temptations. I would like to get a condenser for my Ib (I think, the NY one). I didn't realize the condenser had some serious nicks in it when I got it; I printed with it just enough to get really interested. If I ever run into one of these I won't be able to turn it down, but I really doubt I'll want to take on having one shipped.
Erik, nice review of the IIc. They are beasts to ship - but once in place, it is the ultimate tool for enlarging. Nothing built like it out there. I have a IIc Color (with the filter drawer) - black, wood base board. The one I had before was the late gray with the 100 Focotar-2.
One feature is that you can always recognize a IIc user - a big bruise on the forehead after having banged it against the round knob of the filter drawer when using the 60mm lens and 35 mm film - it drops right down there!
I also like the little "oil holes" on the pivots of the parallelogram arms. Gives the true meaning to the term "clean, lube and adjust".
Over the years I have had several IIc's - and never seen one worn out. Damaged, yes (casting on the frame for the post cracked) thwy will most likely outlast film, unfortunately!
Ok, the Bowden cable can fray and break, but that's about it as to problems. Kienzle in germany still can supply them though.
