Mole in lenses, contageous?
alice
11:27 AM
I have heard different opinions on this issue and not sure what is right, can someone enlighten me?
say if i put a lens (the is infected by fungus) together with my other clean lenses inside an electric dry box, will the clean lens be contaminated?
thanks!
a leica technical guy told me that he thinks the spores are present in the air all the time, and that they grow on certain nutrient deposits on the glass such as condensates from lubricants, when the right conditions of temp and humidity occur.
So maybe keep your lense clean and dry, at room temp, and have them cleaned if necessary.
Moles! I had a dead roach in a camera before, dies right on the Focus Screen of a rRetina Reflex IV. Really ruined the view, but the camera still worked.
I do not think the fungus is contagious; it is there all the time. The damage is done after it "dies" and turns (I've read) acidic. I have cleaned fungus out of a lens that did not leave damage to some late generation coating.
ALSO: UV lamps kills off that stuff, and prevents the spores from taking hold. If you are in a high humidity region, might be worthwhile.
I had a 15mm Super-Elmar-R with a "mite" type of bug on the back of the front element, - it was almost in focus and appeared quite sharp in every shot. I asked Leica (UK) if they could fix it and they said 'no thanks'. I had to sell it to a more optimistic collector and buy another.
thanks!
Fungus is HIGHLY contagious. It will infect other lenses, sooner or later. That's for sure. Keep it away from the other gear. AFAIK Leica Service sends infected lenses back, no CLA.
Bertram
Broke leg <BLAM> 😀
I don't know how much this is true today, but in years past, a horse with a broken leg was immediately euthanised in the manner of the day, because it was next to impossible to set and get the bone to heal, and it was almost certainly a long agonizing period before the horse died of complications.
The line is actually an excerpt from a joke, which wasn't particularly important to the analogy tho funny. A man is pulling a trailer full of horses, wrecks, goes down an embankment. The man survives but has a broken arm. The sheriff pulls up on the accident, the man is up walking around checking on the horses. They come up to the first horse and the sheriff asks "What's wrong with this horse". "He has a broken leg" and the sheriff immediately pulls out his gun and shoots it. Next horse, "Broke neck" <Blam>. What about him, "Broke leg" <Blam>. Then the sheriff asks the man "What about you - are you hurt?" The man immediately blurts out "Nope, I'm just fine, thank you for asking."
Now back to fungus eaten lenses - I realize that there may be permanent etching of the lens, but it just strikes me as giving up too quickly (to save the other lenses in the building) to not attempt to clean or (or replace - we ARE talking about the factory after all) elements with fungus.
XAos said:
I "Broke leg" <Blam>.
Ah , I see, THAT'S where the <BLAM> comes from !
Fungus: Of course it should be possible to get such a lens rebuilt but that would mean to take it apart completely, clean it ALL , get the coating off (etched) and some new one on and mount it all again. AND adjust it !!.
But what about the lenses glued together in an element and the cement in lens sockets itself , if infected too ?
Under certain circumstances this effort can be justified but a new or used lens lens would be cheaper I think ?
Regards,
Bertram
