Godfrey
somewhat colored
Display calibration and profiling have been a part of the computer workflow since I was doing image processing at JPL/NASA in the early 1980s, which is where I learned a lot of the basics required. It was a lot harder to achieve then than it is now, and changed much much much more frequently with all that ancient hardware and phosphor-tube display technology. Never mind the awful digital printing technology that took until the middle '00s to finally get a handle on.. 😀Maybe they can make the computer control the monitor! That's a good idea!
Why didn't they come up with that earlier? I have had a computer and a monitor for more than twenty years, but I have never heard of this problem before. Yes, from time to time a monitor died. Or is it that computers are now more refined so that these problems became evident?
Erik.
That said, if you only ever use one computer and one printing setup to work on, display your images on, and print your images from, you can do completely without calibration and display profiling ... as long as you figure out how to achieve good results, you're good. BUT that's not so good a solution for the modern age where you want to be able to send images around to a billion viewers to view on a billion and a half different displays, wanting the results to look pretty similar on all of them. 😱
G
