PaulDalex
Dilettante artist
Hi everybody,
I am asking further help for my M5. It is a mint 1975 body and works perfectly. I don't think she needs a CLA yet.
Some time ago I had two problems, the lazy frame counter, and a peculiar light leak.
Initially I was planning to send it to Solms, but to depart from her would make me very anxious.
Recently, and I wish to thank again the RFF guys that gave me advice on the counter, I succeeded in fixing it. I think I overrated the problem. Actually it seems to me the bottom sensing lever had just a minimal sticking problem. Now it resets even from, say, number 2.
So I come to the strange light leak, and I wonder if it is a defect at all.
It happened when I made a whole roll of photos of the same landscape, incorporating the sun, with the Zeiss 35 at about 15,30 pm in spring in Italy (I say this because it was a strong sun not a sunset). In a couple cases, but not in the others, the halo of the sun extends through frame separation into the next frame. The sun was at the top of the frame (in portrait) or right at the edge and a slight halo is visible at the bottom of the next one. The camera was on a monopod and I did not care to recap while cocking the shutter.
What do you think? Did I push things to the limit or is it a defect?
Looking at the shutter front and back, also while cocking and firing the shutter, it seems like new. Actually the camera was part of a dealer collection, used to adorn the store. He barely tested it and after I bought it from him, the camera has seen very few rolls passing. I am a hobbyst with very little spare time and many cameras that I rotate.
BTW I noted that behind the hinged door there is only one seal on the right vertical groove. It is the original seal, but it is not foam.
Where can I find this sort of material? Should I insulate all the other grooves?
Thank you in advance
Cheers
Paul
Cheers
Paul
