Most compact 50mm camera.
paniolo
10:32 PM
Hi Guys,
I am on the look for the most compact 50mm lens + camera combo.
The Rollei 35 and Olympus 35RC are just great, but with ~40mm too wide for my general photography.
I look for something similar in the compact camera world but just have found the Vito B and Leica CL as alternatives.
A meter is not needed, but RF would be nice.
The Rollei 35 with 50mm would be the winner, is there something similar?
Best Regards
Tobi
Diax IIb with 50mm Xenon.
A Barnack with a collapsible 50mm Elmar f/3.5
After that, a Barnack with 50mm Elmar f/2.8.
A Voigtlander Vitessa.
After that, maybe a CL/CLE with a new Summarit f/2.5 or the CV 50mm f/2.5.
Everything bigger than those that isn't a folding camera is almost the size of an M body and realistically, bigger than an OM-1 or Pentax MX with a pancake lens.
Phil Forrest
Here's a dark horse: Certo Super Dollina II. 50/2.8 Tessar with rangefinder. 120x80x40mm vs. 95x65x40mm for the Rollei (both folded/lens compressed). That said, the Certo is a somewhat fussy camera to use (even by folder standards), but it is very capable if you're willing to put up with its idiosyncrasies.
The problem is that there just weren't very many (any?) compact, fixed lens cameras made w/ 50mm lenses during the golden age of such cameras (the late 60s through the early 80s). They tended to have ~40mm lenses or wider.
When I want/need a compact 50mm camera, I use a Barnack Leica w/ either a CV Skopar 50/2.5 or an Elmar 50/3.5. That kit will fit in a coat pocket.
There were plenty of normal focal length medium format cameras made though, some of which are about the same size as a Retina. Perhaps something like a Perkeo?
Had same question/quest a couple years ago, my answer was Barnack Leica + Elmar 50 (very slim but heavy and a bit less intuitive to use compared to modern camera) or CL + Color-Skopar (Modern UI and very light but thicker to carry).
Well, if an Olympus RC is compact enough, then a CL + CV50/2.5 should be fine; it's not much bigger. But you're not going to find a camera as compact as a Rollei 35 with a 50 lens.
Collapsible elmar on Leica body. 3.5 elmar is almost flat. 2.8 is around 1/2 "
Rollie 35 is a gem and would be my pick if only size matters.
I don't believe they get any smaller or more sleek that
the Voightlander Vito II. At least I have been impressed
with mine.
I don't believe they get any smaller or more sleek that the Voightlander Vito II. At least I have been impressed
with mine.
If a rangefinder requirement is not critical, then I would agree with this. The Vito is really well-designed and pleasant to use.
