MR-9 battery adapter issue
folksnake
12:38 PM
Hi All-
I ordered a battery adapter for my Canonet G-III 17 from CRIS and just got it. Excited, I tested the battery itself (new 386) and it was at 1.584V. Ok, it's fresh!
Inserted it in the adapter and the voltage now read 1.555V. This is one of those adapters that has the built-in diode to drop the voltage to 1.35V.
Is this normal? The instructions say "386 battery voltage is reduced to 1.35 volts when the camera or meter is turned on."
Does that make sense that the adapter would need a load to drop the voltage correctly? What about the original mercucry batteries--were they 1.555V also, until the meter was turned on? Odd.
Admit I'm a little confused, and a little miffed, in that the package cost me nearly $50.
Thanks!
As I recall from previous discussions here, when there is a load on the battery/adapter, it measures 1.35v. Without the load, measuring it with a modern digital meter will show 1.55v. I have an older analog volt-ohm meter, and it shows the desired 1.35v.
These adapters have worked very well for me and I would expect yours to function as intended.
- Murray
What CMur12 said. Absolutely correct.
These adapters are very well made and reliable. You can be assured that when the camera circuitry loads it, the adapter will provide the 1.35 volt output.
Yes, it does make perfect sense, from an electrical viewpoint. A modern DVM draws very little current so it doesn't present a load to the adapter. No current flow = no voltage dropped across the diode, so the meter just reads the full battery voltage (almost).
Excellent! Thanks so much for the reassurance. I was hoping that nothing was amiss, but couldn't be sure.
Now to figure out why the Battery Check indicator won't light with the adapter, but does so with the old battery that was in the camera when I purchased it...
Thanks. Invaluable to hear experienced responses!
Mercury and silver oxide cells are voltage sources, so they show their nominal voltage on low loads (e.g. digital meters) even way past their useful work life, while they are decreasingly capable of maintaining any useful current over time as they discharge. Simply measuring voltage accordingly won't do, and even measuring voltage under regular work load often does not tell you whether the battery will fail another minute on. To get a more reliable assessment of the cell status, battery indicators often work by putting a unusually high load on the battery - where a stale battery will black out while a good battery can handle that.
These test loads may be too much for the adapter, as drop diodes have maximum as well as minimum current limits.
Thanks to everyone who has replied. You're all spot on, of course. I'm good now 🙂
I also got a response from CRIS and they sent out a pdf explaining how to properly test the adapter (10Kohm resistor in the testing circuit). If the voltage reduction happened without a load, it would constantly drain the battery, even when stored ans turned off. Makes sense.
Thanks again for straightening this out for me!
