Martin Horne
I've acquired a beautiful MR Meter thanks to a fellow forum member. I'm new to the meter and to be honest manual metering in general. The meter is boxed and I have the instruction manual which I understand completely.
What I don't have is the confidence yet that the meter is actually metering correctly - I'm half way through a film so wont really know until it is finsihed and processed.
When I test the battery the meter arm swings from the back plate side straight to the black dot as it should. I then set the film speed by pressing the approprite button and take a reading before setting the aperture/shutter speed.
In bright light the meter goes all the way to the top of the scale as you would expect but it's not far short of the top of the scale in a dimly lit room with a few lamps and TV either. This morning whilst fiddling I covered over the front of the meter and low and behold was still getting F4 at 1/250th. I assume I've a problem or am doing something wrong...
I'm going to send the camera and lense to CRR for a CLA when Peter can take it so do I send the meter or am I making some newbie error that I can easily sort out such as the early stages of a new battery being needed or somesuch?
Thanks all.
Thanks all.
