My coolscan 5000 is dead again
Nachkebia
6:18 PM
Hello! :bang: :bang:
So today, I have developed my lovely kodak t-max film, waited for it to dry, booted up windows, turned on scanner, loaded nikon coolscan, "Nikon Scan was unable to find any active devices" I tryed to change cables, I even took the whole scanner and installed it on laptop! nothing! I get the same msg "Nikon Scan was unable to find any active devices".
Is there anything I can do? or just take it tomorrow at nikon service? btw this has happend to me allready couple of month ego, it was in service for 1 month (I think) and finally they said problem was with PSB (I think) when I asked for reason there reply was " it happens to everything that connects to pc" well I don`t wont this to happen again! I think there is major problem with my PC itself (usb devices) What should I do? how can I check my PC? what should I do next time to avoid all this hastle? :mad: :mad:
P.S. all this might be because of my negative additude towards M8, so digital stricked on me, sin`s sin`s.... :)
Thank you in advance!
did you try banging it?
just kidding...
i would turn everything off, wait a few minutes and turn it all back on again.
then i would call my friend the computer guy.
Doesn't look to good. Does your scanner turn up in the dialog to remove hardware? Don't know how it's called in others than the german version, I mean the icon in the taskbar where you disable removable devices like pcmcia cards and USB card readers and such.
gabrielma : From my understanding PSB is the main part that conects scanner to pc.
johne : Yes I did, there is not such thing as driver, you just have to install nikonscan, and I have latest version (4.0.2 or 4.2.0)
back alley : turn it off? I did all that stuff, turn on, off, pc, scanner, change cable usb, power... everything :)
Socke : No nothing, as if nothing has been connected to PC...
Nachkebia, PSB is probably PCB - Printed Circuit Board. 1st Level support persons happily snap up TLAs (Three Letter Acronyms) so they can say something technical to a customer who might know more about the product then they themselves :)
I have a USB keyboard which doesn't show up in the disconect hardware dialogue and which isn't activated/installed/whatever when I connect it to any of my computers. So I dissasambled to look what is inside and I found one of the chips on the board has literaly blown up. I had the keyboard daisychaind with an external harddisk and this must have caused a short or something and the blown up chip may well have protected my Notebook.
Looks like your scanner met a similar fate, without knowing more but that it happened the second time I'd blame a faulty powersupply on the scanner.
Yap Socke, thats what most probably happened, I just took it to nikon service, I hope it will be fixed before I come from my india trip, Now the main thing is how to avoid this next time, maybe change monther board on PC? or just tower and powersupply? because I think there is a problem with usb, but I can not explain to PC support..
Thank you!
