ZorkiKat
ЗоркийК&
- Local time
- 8:01 PM
- Joined
- Jan 26, 2006
- Messages
- 2,070
This is the device which I made about a couple of years ago to address the lack of strap lugs in FED and Zorki cameras. The original cases were fine for carrying the camera, but the cover often got in the way. Cutting off the front part of the original leather cases of these cameras was out of the question for two things: I didn't want to destroy them, and second durability was also an issue. The old leather could break and the rivetted straps were often brittle.
A better one would be a case which was robust, and one which would not make the cased camera significantly larger.
So I made one, using readily available materials here. The body of the device has a galvanised sheet skeleton. Then this was lined with cardboard, which was then covered with leather. The outside has a black cowhide skin and the interiors, with suede-like pigskin. The lugs on the sides were made from soda-can tabs, flattened and smoothened. These were rivetted to the metal frame.
The strap is made from cloth strapping material, then sewn in a loop. It has an adjusting buckle was also fashioned from a soda can tab.
This device fits both FED and Zorki cameras. The cameras attach by a screw at the base. This screw was a loose one which came off from one of the original cases. The next case I will make will have some form of stop in the front to prevent the camera from swinging out. This hasn't happened so far anyway, even when a somewhat hefty lens is mounted on the camera.
Jay
Jay
