my gsn has stopped working... :(
cp_ste.croix
At the beginning again.
7:24 PM
So my recently aquired GSN seems to be on the fritz. I'm not sure what it is, but on first guess I thought it was the battery, seeing as none of the apprpriate lights work anymore. Shutter speeds change from the default 1/500 to longer ones, but with no predictability. I took out the battery and tried it on B and it didn't work, it sometimes defaulted back to 1/500 and other times was much longer or would stay open even after my finger came off the shutter release. I don't think the battery should be dead already...ARG!!! :bang:
Any ideas? I really like this little camera and have no cash whatsoever to replace it...
can i assume that it's called the Pad of death because either
A) attempting this repair may cause one to have a heart attack in frustration?
or
B) if you mess up the repair, the camera dies?
Yeh, they're not bad, but they're not his best feature. :)
And, yes, he does everything but walk on water!
hey doll, maybe you could take a quick shot of the g'man's BEST feature for all to share.
(probably be his big heart)
;)joe
You will just have to use your imagination!:)
(Boy, is his reputation going down hill.)
We discussed the "pad of death" replacement problem in this thread.
http://rangefinderforum.com/forums/showthread.php?t=4384
Try the pin in the pad method. It's not so hard.
greyhoundman said:
I don't know of anyone dying from it. :)
Though I've heard it can cause the consumption of large amounts of focusing fluid.:)
AND they are never quite the same after! :p
Mike :D
