Griffin
Grampa's cameras user
So I have my mom's old Canon ftb w/ Tokina 17mm and I have this Hanomat flash thingie. On the back is a little dial which I can rotate to the correct ISO and then the scale at the top tells me which aperture to choose for which distance. Now.... which shutter speed do I use? The camera has a red "60" on the shutter speed dial, so I presume anything 60 and under will do, as the curtains will be open when the flash fires, right? Is there no risk of overexposure if I go for 1/30 or 1/15?
This is the flash in question:
http://www.ebay.co.uk/itm/Vintage-H...age_Cameras&hash=item3f1c53bf62#ht_500wt_1054
You can see the green round switch in the middle. It has three positions, to the right reveals a red circle below the white dot. The center position is shown and of course the left position with the green circle below the white dot. Does anyone have any idea what all these positions do?
Ok, thanks in advance!
Edit: Just found a manual for my flash. I could never find one looking for Hanomat, but Hanomex seems to be the same unit. :http://www.cameramanuals.org/flashes_meters/hanimex_bx550_flash.pdf
