gdi
I just got an X-Pro two days ago. I was getting used to it and figuring out how to make AF acceptable and everything was going pretty well. Then I had to go and screw it up! The camera and lenses (18 and 35) were at V 1.01 and I updated the body to 1.11 in anticipation of getting an M Mount adapter.
Now I see the following problems:
1 - I cannot get the full display of info in the OVF even though I have checked all the options in the setup Menu. It is limited to EV comp, Mode. SS Aperture no matter what I set. Maybe there is a setting I missed when I had to reenter the settings after the upgrade?
2 - THe lens chatters more than it did before! In fact I don't think it chattered at all before the update. At 1.01 I never noticed it, now when I am in S AF mode with the View Mode set to Eye Sensor it makes this noise when my eye is up to the OVF, it doesn't when I am using the LCD. I am sure this didn't happen before.
Any ideas on what might be going on? Maybe the new Firmware is not working properly? Hopefully this a newb setup problem...
Thanks
Thanks
