Need advice on changing M6 advance lever
pizzahut88
7:40 PM
I have a M6.
But I like the MP style advance lever a lot more.:p
Is it possible to change the M6 lever to an MP type?
I am in Hong Kong, anyone know where I can get Leica parts?
Could this be do-it-yourself at home job?
Cheers, Manfred
Lots have done it. I would do the reverse ;) if I had an MP I'd want the modern swinging arm film-advance lever on it. Way better... :D
Art, I replaced my M6 advance lever last year, and now I'm considering replacing the preview lever.
What's involved in removing/replacing the preview lever?
You need to replace both the lever and the screw, with the M2/3 parts. Not a problem and VERY easy to do.
You can get the advance lever from DAG for $50 but you will need a 5/8 inch (15.9mm) flexiclamp from micro-tools.com to remove the ring. If you try to use anything else to remove the ring you will damage it..
I made my own
I made my own
I used some scrap 3/32" aluminum stock an a couple of drill bits, and a Dremel tool. Fast and easy.
For the new/old style screw for the preview lever I just used two jewelers pointed tip screwdriver tips taped togrther, as I didn't have the two bladed spanner. Worked great.
Art, I'm sorry - I should have been more specific.
The M3 style screw can be loosened and tightened with a pin wrench, but what about removal of the original blind screw? Did you use a rubber grip, a flexi, or something else?
I'd like to avoid damage to the original screw if at all possible.
Thanks!
For that one I used a wide rubber band with thin hemostats.(a surgery instrument) I was going to make another flex clamp but I tried it with the hemostat and the rubber band, so I didn't bother.
Thanks!
OK, a roach clip and a rubber band - I'm in!
I assume you hold the lever stationary when you remove the screw? I seem to recall the lever is keyed.
Thanks!
Anyone have any more information? I am about to embark on the film advance lever replacement...
Any pictures of the procedure?
You have to do it right, with the right part, otherwise the M2/M3/M4 metal tip will touch the shutter dial.
