Need Help with Epson Raw Plug-in & CS3
sonwolf
7:33 AM
I installed the Epson Raw Plug-In into CS3 but the ERF files always open in Camera Raw. I used the 1.21 version of the plug-in from Rich Cutler's site and have tried it in the following folder locations:
Adobe Photoshop CS3 > Plug-Ins
Adobe Photoshop CS3 > Plug-Ins > File Formats
Common Files > Adobe > Plug-Ins > CS3 > File Formats
Following advice from previous posts, to open the ERF file, I am using the open dialog with Epson Raw Plug-In chosen as the file type but ACR still grabs the file.
Does anyone have a solution to this problem?
When you Open a file, there's a Format chooser at the bottom left of the window. This may already have Photoshop Raw selected. Change this to Epson RAW Plug-In.
Hope that does the trick.
Nick
I am not sure this will help but I only open .erf files from Epson raw itself. I do not believe Epson raw is adecuate to visualize files as the window is to small. It is great to process them but I do a batch when I download them from the SD card then do not use Epson raw to look at them.
Nick,
I am already choosing the Epson RAW format with no luck.
Are you using CS3 and in which folder did you install the plug-in?
If I remember correctly (this applied to cs2 and may be different for cs3) you cannot have both the adobe camera raw and the epson raw plug-in in the folder together.
I have a similar problem. I've installed the Epson Raw plug-in, but it doesn't show up in the format chooser list in the "Open" window. I've tried put the plug-in everywhere I could think of, but when I launched PS the Epson Raw simply wasn't there.
Can anyone help me with this? Thanks in advance.
Did you upgrade to Camera raw plugin v. 4.4.1 folks?
Causes no compability problems with Epson raw plugin v. 2.1.1. in CS2 for Mac at least.
Edit: Sorry i meant Epson raw plugin *v. 1.2.1*
I cannot find Epson raw plugin v.2.1.1. in the Epson supports sites I have checked.
The latest plug-in I see is 1.21, which appears to be for Mac PPC, rather than for Mac intel.
Any guidance?
Hi!
I have CS 2 (iMac G5). My Epson RAW plugin sits here: library/application support/adobe/plug-ins/cs2/file formats/epson/epson raw plug-in.
Hope, this could help!
Cheers
