Need help with Minolta 5400 V1......
TRIODEROB
12:05 AM
So I picked up a used 5400 off of ebay and cant get it to work.
using Vuescan I get a small window stating to remove the tray before calibrating.
I click the window and then thats it- Vuescan tells me there is no scanner !
the scanners green light keeps flashing when it should be solid.
I can see that my computer got the scanner driver in the device manager from vuescan.
and on top of that I can not find anywhere to download the dimage software off the net which will work with 64 bit windows 7.
can anyone help me ???
The procedure I currently use with Vuescan is:
1. Turn on the scanner
2. Wait a few minutes (the fluorescent light source must heat up to get stable)
3. Launch Vuescan
4. Click OK to have it pre-calibrate the scanner
5. Wait until the light stops flashing
6. Do the final calibration with Vuescan->Scanner->Calibrate
7. Now you can insert the holder and scan
At point 5, if the light won't stop flashing after Calibrate, you may have an exhausted lamp. :(
Fernando
