Negative storage- keep every strip, or individual frames?
On rolls I develop they are stored in a poly sleeve in full strips. Several rolls will fit in in a small box, loosely coiled. Since my scanner will scan an entire roll this is efficient for me. This means the keepers and the losers of course. 🙂
Every Frame in 6 frame strips... with a Contact sheet of my computer edited frames in a hanging sleeve that holds both!
I don't wet-print. I scan them all at 3200 dpi (55mb file) (V700) and edit the best frames.
I do keep every roll of fillm I've shot in strips of six ... though sometimes when I look at the digital scans of some of my early rolls I wonder why I'm keeping them! 😀
I used to keep everything in strips of six ( because 6 is the max frame count my film scanner would take).
For the past year I've been going through my archive and cut single good images. The rest goes to trash.
I keep all my images of family/friends regardless.
A.
I keep all my negatives stored in a cardboard box in sleeves and that within envelopes. My digital images however I am concerned about! 🙂
There is nothing sacred about lousy shots are negatives IMO, and everyone has them. If after scanning, a negative strip has no images of any value (good shots, historical or documentary value, family) the strip gets tossed. I catalogue my negs according to strip number. On some rolls I have only kept one strip.
I keep 'em all, but in 5 frame strips, and then put those in PrintFile pages, and then put those in 3 ring notebooks, and then put those in dust tight boxes. I have all of my negatives going back to 1979.
I cut them to 6 frames strips - filed in Printfile 6 by 7 strips. Using reloadable cassettes I tend to get 37-38 frames. Each file page is numbered and camera/lens/film/developer noted on it.
My files go back to the late 60's, with some missing (moving often and long distance resulted in loss of boxes of filepages!).
What I like to do sometime is to go through negative files that go back 20-30 years. The frames that were marked for printing are usually OK - but you also find that what you rejected then - now has some images on them, maybe long forgotten - but almost takes on a historical interest.
At the latest count - about 10 000 rolls filed and annotated and some 1000-1500 rolls unsorted in binders. These are all black/white - then there are boxes and Carousel trays filled with Kodachromes!!!!!!!
Yup, I keep them all, just like this ^
Only thing is mine go back to 73 or so.
...Terry
Strips stored in Arrowfile compact ring binders ,five negs to a strip.
Numbered with camera and lens recorded .
If there is a run of duff frames I`ll discard that strip.
Lots of Leica trays filled with Kodachromes dating from the early seventies.
Keep everything, that way you can look back at your older work and chart your progress.
I have every negative back to the late 1970's cut into 6's in Kenro sleeves and archive binders which have index cards with subjects.
Some early colour negs processed in a mini lab are in fours-they go in six sleeves.
Cutting into singles is a very bad idea, it means that say a Fuji Frontier can't print your work without stopping, putting in a manual mask-they may charge you extra fro that also they are easier to lose and damage–if you must cut into singles put them in slide mounts.
How much volume does 10K rolls take up?
