ferider
Sure, unless you want it to work well with lenses under 90mm.
Why do you think Leica hasn't done it? Spite?
The M8 was designed more than one technology generation ago. Times change.
I wonder if people would mind? I supposed they would.
I wonder how far you could chop down a D700 if you chose to convert it to a rangefinder?
WTF is a 'technology generation', especially in the context of the laws of physics, digital RF cameras and telecentric requirements for digital sensors?
Thanks for the kind words, Roger.
Technology generation is 18 months in the semiconductor business.
Google for "Moore's law".
Meaning new sensors can have more bits per pixel. Increasing the dynamic range.
Each additional bit allows for one additional stop of vignetting that can be corrected in software.
Roland.
Double Negative.
Whay are you "sure it can be done" I hate it when physics (or any other science) becomes a matter of opinion rather than fact. Are you an optical or electronics engineer?
When will people accept the physics on full frame.
Light can hit film at any angle and record an image.
Sensors have depth created by the micro lenses on them and they rely on light hitting them as perpendicular to the sensor plane as possible.
Move off centre and the image corners becomes darker.
Move the lens closer to the sensor and the image corners become darker
Increase the sensor size and the corners become darker.
These are not easy issues to sort out and Leica don't have the resaerch budgets of Sony and Canon. Nikon don't make their own full frame sensor. They buy from Sony, probably because they can't afford the development costs.
Just because we've moved on a few years doesn't make things suddenly possible.
SR
No reason you couldn't stuff a full frame sensor into an RF.
So when, exactly, did I say to either of you that Leica could - or would - release a full frame RF tomorrow?
All I said is "there's no reason it can't be done." Sure - with current technology and economics maybe not. But with the proper funding and research it very likely WILL be done. Maybe not tomorrow and maybe not by Leica - but it will. 😉
I have resisted buying a digital Rf for several reasons. One of the main one is that if I use a 35mm lens -thats the angle of view I want! Not some 41,4mm or crop factors! If Nikon manages to produce a DRf with a D700/D3 sized sensor and 15-16Mp capacity - I am buying one. ANY digital RF with smaller sensor is of no interest to me.
The D3/D700 sensor is quite incredible. The high speed capacity is nothing short of phenomenal. I have seen images - RAW, shot at 4000 iso that look like 400 iso on film!
As for the "how to do this" - thats up to the Sony/Nikon team. The physics is interesting, but it can be solved. Why Nikon would do it? It is bragging rights - they are looking at a line-up of high performance cameras, from the D700 (or maybe even a simplified $15-1700 "lesser" version), the D3, The D3x and a Drf. All based on the same platform too.
I only hope that they can build-in a good bl/w program into it too. Now at 2500-3200 iso - who needs a Noctilux, just use the Summilux 50f1.4 Asph or the Zeiss C Sonnar 50f1.5 instead! Saves a lot of money!
