New M6 & Cron owner seeks hood advice
BennyBoy
4:09 AM
England
I recently got to such a point of frustration with my other 35mm rangefinders that I splashed out on a used M6 classic and Summicron 50. I'm stupendously happy with my purchase and have no clue why I didn't make the purchase much sooner.
So far I've only one very minor quibble with the set-up, and this is the reversible hood/cap combo that came with the cron, I'm no gear expert so have no clue what version this is (S/N is 3481133), but I find the hood/cap combo very cumbersome to use and a little 'tight'. Is there an alternative I could try that may make life easier for me? Am I just being a bit too overprotective of my gear?
I did some searching and now know that my M6 was made in 1988, and that the Cron is 5th version made in Germany. Is there a metal hood/cap combo available?
Did some more searching about and HU12585 looks like the metal equivalent of the plastic 12538 hood I have, is the metal 12585 easier to remove, the detents on this plastic one are a little limpet like...
I used to an have plastic and a metal hood for the 50. In daily use it didn't matter much. The metal one of course did feel better. But the plastic did well also.
cheers,
Michiel Fokkema
I'm in a bit of the same situation except the only cap i have for my 'cron is for the hood and not the lens itself. I never use the hood as it make my kit seem conspicuous. So I have to remove the hood and cap everytime I want to shoot. It's getting to be a nuisance and I've only had this lens for a couple weeks. Anyway, I think I just need a lens cap so I can leave the hood at home.
otoh, I replaced the plastic hood with a metal one and I found it fit much better - much easier to put on and take off, especially when a filter was on the lens.
The lens front element is about 6-7mm recessed from the lip of the filter ring on my copy of the lens, so I'm not sure there's a huge flare issue anyhow, so in light of the comments about the metal hood being much the same mechanically as the plastic one, a clip on cap could be useful - I shoot with a 13131 UVa filter attached all the time anyhow.
(EDIT)
Pablito posted as I was typing... would be nice to hear some more opinions on the metal hood...
I'll only re-state the old rule: There is no photograph which cannot be improved by the use of a hood. It's all the more true if you use a filter always.
I use 12585 metal hoods on both my 35mm and 50mm Summicrons. I never reverse the hoods, even in storage (although they hardly ever get stored since they are almost always in use). I never use front lens caps--I use B+W UV filters.
You can get a non-vented metal hood from eBay dealer heavystar as well:
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=140143445055
Some of these hoods are not the best quality though.
Since you have a UV filter permanently on the front, maybe the best solution is the little metal Leica hood for the current Elmar-M 50mm/f2.8. The Leica part number for that hood is 12550. It's very inconspicuous (those big vented hoods look ridiculous IMO) and will provide nice additional protection for your lens. 🙂
I have looked at the hood 12550 and I don't know if it is meant for anything other than the new 50 elmar2.8M. You might experience vignetting with a 50 cron at f2.
I've had my 12585H since about 1966 (along with the 8 element v1 35 Summicron), so this popular item must have an impressively long production history. Excellent hood.
