rogue_designer
Reciprocity Failure
You can get a usb to firewire hub to use with your 9000: http://catalog.belkin.com/IWCatProductPage.process?Product_Id=199941
I think that requires a firewire connection to the computer to use the firewire ports.
It's true! The libraries I use are tightly access controlled, so leaving a computer locked up even for a few hours is no problem. At the Staatsbibliothek in Berlin you get given a pass when you go in with a computer and have to present it when you leave, at the British Library there's cameras all over the place and you get searched on leaving the reading rooms - and at both getting a readers card involves bringing lots of ID, having a proper ground for using the library etc. It'd probably be OK leaving a computer without a lock, but I don't want to tempt fate. And those all so essential trips to the cafe for yet more coffee are really annoying if you have to carry a laptop - you can't take bags inside so you have the laptop in one hand, a cup of hot liquid in the other, maybe a crossaint balanced somewhere.... If only Apple had thought of this when they made the Macbook Air 😉I had to laugh when I read that... No wire cutters in your part of the world? Or it's just not done? 😀
The MacBook will be fine.
You can get a cheap adaptor from the Apple store that will allow you to connect firewire devices (such as your scanner) to your MacBook. This is NOT an issue.
I suggest that you use a fast external hard drive for your photos. Then you won't be filling your internal hard drive so quickly. They are cheap these days.
In any case, a 5400 rpm hard drive will work well.
You MacBook monitor will work well provided that you don't intend to edit more than one photo at a time.
So don't worry - you will be fine with the MacBook - no need to save for the MacBook Pro. If you save your money, use it for an external hard drive or a larger monitor, not a MacBook Pro.
1. Firewire. Not only will this be necessary for the Coolscan 9000 (I have one) and any other non-flatbed, it is also a much under-used and underrated protocol. For making continuous backups, Firewire is also necessary as it allows you to make bootable backups of your entire system - something not possible with USB. HardDrives SHOULD be bought with Firewire 800 and then daisy-chained to the scanner (another pro of Firewire).
3. Graphics Card: I assume you're going to be using Vuescan. And Aperture (or Lightroom). And Photoshop. At the same time. My MacBook Pro with the 9600M active struggles with this. A MacBook wouldn't have a chance.
The only upgrade I was planning on getting with the Macbook is 4 gigs of RAM. I am fine with using external hard-drives because when I'm at home, I planned on having the laptop closed and using it like a desktop with an external monitor/mouse/keyboard/speakers.
If you're going for a new machine, I say hang the laptop for now and go for the big iMac: FireWire will be there, and much more bang-for-the-buck in terms of performance.
I have been standing in front of similar decision and choosed new white MacBook (because it's more portable than Pro).
