aizan
Whenever I read that a lens is "sterile and clinical," I think "Niiiiicccceee!"
I don't know why the terms, "sterile" and "clinical" keep on being used for modern lenses. Why the pejoratives?
Does anyone say "sloppy", "hazy" or "fuzzy" for vintage lenses that render low-contrast or soft wide-open? Or "distorted" when demonstrating extreme curvature of field?
Here is a comparison of the original 8-element wide open and the replica, looking for field curvature. Focus in on the green sign. Areas at the sides / corners are not sharp in the original.
orig at f2 by woodswoman57, on Flickr
Here is the same scene with the replica, which shows much more sharpness in the designated side / corner areas.
replica at f2 by woodswoman57, on Flickr
Therefore, it seems that the original 8-element does not share the same degree of field curvature.
Ed, very much appreciate all the time and effort you and others have put into comparative shots between the original 8 element (which I used to own) and the replica. This last pair of images you posted though call something else into question. Its not just the background right and left sides that are noticeably sharper in the replica but virtually everywhere one looks, including the entire area just behind the sign that you focused on. It appears (at least initially) that there might have been mis-focusing with the original 8 element as though it was front focused a bit and thus everything beyond the sign is much softer in terms of sharpness (and contrast too) when compared to the replica. I don't recall this pronounced a difference in previous comparisons. Thanks again!
Dave (D&A)
Ha ha, yeah - well, character. Depending on what one likes in the image quality department. Over the years, I have come down to my own conclusion that I prefer a balance of character and a clean perfect image. The newer lenses have a "perfect" look. Flat field, ultra high contrast, sharp corners, etc etc. That is why I find that the Leica lenses from the 50's to the 70's have a great balance in all these areas. The 90's up until now have brought more perfection in all these areas but something is missing I feel. It's like this: for super clean and high contrast landscapes I take out my Summicron R 50/2 Type II. On digital it's my Fujinon 35/14 R or the 18-55 zoom. The images they produce are perfect. With people, and most things that I want a certain "look", warmth or particular character I take out my 50 Cron Collapsible, DR, 35/2. The lens with most magic is my Summaron 35/2.8 - colour or b&w. 90/2 type 1. Leica Elmarit 90/2.8 is a great balance between both worlds. So it the Cron (1968) - a great lens. The Voigt 35/2.5, 21/4 are great lenses but don't know where to place them yet, I haven't used enough but they are sharp. The CV 35/2.5 has a particular smoothness in b&w - this lens is a keeper and I can't tell you why yet. Oh, man... GAS GAS GAS...
The focus now is on the Replica - no love for my Voigt lenses.
Funny... My MOST used lenses because of this character balance on digital and film are: OM Zuiko 24/2.8, Cron 50/2 R, Elmarit R 90/2.8. The OM Zuiko 24/2.8 is almost glued to the Sony a7. It is such a versitile looking lens and the image is punchy, nice DoF for most things. Not a perfect lens, but has something about it. Each to their own.
I never gave much thought to field curvature outside of macro.
What happens when you stop the lens down a bit? Does it flatten out? I hardly ever shoot anything at moderate distances with the lens wide open.
since you highly appreciate the 35/2,8 summaron but at the same time find the replica interesting,
would you sell your summaron eventually to stick with the replica?
the reason i asked because now i have a 35/2,8 35/2 v4 and upcoming replica (well i hope kevin didnot forget me); i wonder what should i do with 3 similar focal length lenses.
I don't quite know about that, I'm seeing sharpening of the very extreme left corners on the original as well.
I consider the Summaron 35/2.8 a special lens. It is high contrast in the centre, lower contrast corners because of veiling flare.
The Summaron 35mm f/3.5 and the Elmar 35mm f/3.5 are also very fine lenses. I consider the Summicron 8 elements not nearly as good as those, it flares easily and has a low contrast. But I understand that many people like the lens, just for that!
Erik.
The original Field Curvature has a shallower, smoother more extended roll off from the corners. There is less contrast but veiling flare and coma is essentialy the same as the Replica. The white balance is warmer.
My conclusion I would assume is that the Replica's steeper roll off of the depth of field due to Lens Field Curvature has been adjusted to increase corner sharpness which would be a alternative compromise and a discretion by the designer.
